Driver, not Mechanic
I have a Jaco Digital 0-100 PSI from Amazon because I didn't want to spend double on a Longacre.
I used to carry one of various types, and inflated from my compressor or at "free air" stations... till my last two decent ones croaked....
No regrets ... this rock$ ![]()
And if the weather in the morning is in the 30s but the afternoon is in the 60s or 70s, the difference from cold tires in the morning to hot tires in the afternoon can be 10-15psi.
Team California
I'm still learning my Macan ... the 4 tire pressures display has gotten my attention recently ... the pressure on the RF is -2 recently... and mebbe I don't get my tires "hot" ... haven't noticed larger deltas with outside temp changes.
I will be watching this ![]() It's what I do
Counterclockwise?
A battery that works as a battery charger?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I see you
Sorry no...battery + a charger
![]() I see the inflator for $199 at Ace but the battery and charger is over $300.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 01-21-2026 at 09:44 AM.. |
If you've got DW batteries, then that's probably your best option.
If you were set on the MW then your best bet would be something like this.
But obviously, if you've already got these tools and DW batteries, then this sort of purchase doesn't make much sense.
Can't read it at the bottom, but your blue point and mine (I have the longer hose model) both say "made in USA"...go on a snap-on truck today & look at a new one? Yep...China.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
If ya have DW stuff ... yep! They have gotten rather proud of batteries and a charger I reckon ... ouch .
Back in the beginning I'd buy a tool that came with a charger and battery. Some tools don't come with batteries now. When that's the case, the price goes way up to buy a tool and charger and batter. I've got 2 of the Milwaukee M12 chargers and 2-3 batteries. I've got 3 Ryobi 18V chargers and batteries. So now if I can buy a tool sans battery, I'll do that to save a buck. I just bought an M12 4Ah battery for my milwaukee stuff because my old batteries were getting OLD and sucking wind.
I have a digital Longacre gauge that I like a lot https://longacreracing.com/products/2digitaltirepressuregauge-basicstyle.
It has a bleed valve and measures to 0.2psi which is accurate enough for me. I don't know why I still have pencil type gauges.
Paul 82 911SC - 3 yrs of fun (traded-in) 2011 Cayman (simply amazing, smiles for miles) |
I converted to a dial to have better resolution to enable me to be consistent. I set my tires to the same pressure side to side and do my best to keep them there. My TPMS has always been pretty accurate too. The battery in my front left finally died, so my next set of tires will require new TPMS. Hopefully, my next set works as well (which are at least 12 years old).
I'm not OCD, well, maybe just a little. Sent from my SM-S916U using Tapatalk
"A little nonsense now and then is relished by the wisest men." Wonka |
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
