This is how my dash displays the TPMS data (or trip computer data).
I just had Discount Tire swap tires from one set of wheels to another - and also replace the TPMS sensors on all corners. They charged $69 for each HUF UVS7060 TPMS and $39 for each tire (dismount/mount/balance.)
I did have to go back twice as the TPMS programming ended up failing. The dash showed a learning message - but regardless of time and driving distance it would fail and go inactive within an hour or so. On the 2nd trip back this AM, they used the Panamera option for programming rather than Carrera and that did the trick. Apparently the programming tool they use has some quirks when it comes to Porsches.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
The wires for the TPMS run on the right side passenger footwell. Easy to cut and get rid of the dam light. I can reattach the wire if I ever sell. My 08 Tacoma.
disband
There is a program for many Chrysler/Jeep offerings called JSCAN that allow you to adjust the pressure level down. I went to zero in my jeep and when I swapped out wheels with standard, non TPMS valve stems and the light never came on. I've looked and looked for something like that for my Duramax and can't find anything so the light burns brightly on my dash.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ |
