canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Senior Member
We just did it here in Phoenix a month ago. Whole group of us got together and pulled a Pelican's engine and tranny, then proceeded to take the engine apart to see what went wrong inside.
Had a good time, and helped a friend in the process. Same thing could work here...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Well I haven't been able to get a contractor to come out and look at the job. Guess its the busy season.
So if any of you guys are GCs and are interested in some work just PM me. Or maybe you know a GC you'd be comfortable recommending? thanks gang
big blue tricycle stare down the darkness and watch it fade |
Senior Member
I'd get under there with some screw jacks and some hydraulic jacks and big pieces of wood (and perhaps some beer and cigarettes) and jack it up. Dig. Place wet concrete or dry blocks. Voila!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Hey ya'll watch this
Hoots Midvale School for the Gifted Class of 1990. |
Free minder
I`d like to be Superman too. He has a simple solution for every problem. Did not he fix broken studs on his SC, by just opening his engine, replacing the studs, button it back up and voila ! But since I am not Superman, what I would do with the house is take a reverse mortgage...
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
You do not have permissi
This probably won't help, but on one of the "fix-it" type shows (Holmes on Holmes?) there was a Canadian guy demonstrating a new sectional/segmented foundation repair tecnique on an older house that couldn't be lifted. Can't remember the name, sorry.
Meanwhile other things are still happening. |
Information Junky
Wood structures are surprisingly flexible. (easily jacked) Superman and Steve both are on target. Furthermore "doing it right" is NOT a 200 year design solution. (tho' a 200 sol'n is likely what a contractor and/or code may push for.) Just tell the contractor that you're looking for a 40 year solution.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
so if we figure this will take two weekends, 1 for demo and footings and 1 for construction, when are we doing this?
permits can be pulled by the homeowner in NJ if this is your primary residence.
Chris the more i learn, the less i know |
with all these pelicans in the tri state area, i'm sure qualified people will chime in.
NWNJ, like the water gap?
further East, Lake Hopatcong
