Thanks Snowman. I understood the test and agree that it would be the best way to test. I was going to do that Sat.
Fortunately, even though I didn't work on it at all tonight when I got home, I managed to find and fix the problem. I got a wild hair and decided to test a couple of other things. Figuring that the wiring may not make much sense I went ahead and tested a couple of other outlets. There were two outlets in a third room that were also on this circuit, and, I believe, the beginning of the circuit.
I plugged my tester into one outlet and turned on one of the switches and noticed my tester do it's thing (hot/ground reversed). I also noticed a buzzing noise. I took that outlet apart and put it back together and again noticed the noise which led me to the culprit. It had a connection that was obviously bad. I took it apart and put it back together and everything is working again. I still have all of the outlets uncovered, but I put the switch plates back on. I'll put the rest of the house back together tomorrow.
Thanks everyone for all of the help!!!
Old 05-02-2007, 09:53 PM
Originally posted by masraum
I noticed my tester do it's thing (hot/ground reversed). I also noticed a buzzing noise.
I trust you put it back together with[list=1][*]clean piece of the wire[*]oxidation preventer on the wire.[*]the al compatible outlet is clean [*]a working smoke alarm[/list=1]
Old 05-02-2007, 11:24 PM
good job
Chris
the more i learn, the less i know
Old 05-03-2007, 04:05 AM
Yep. I know, the buzzing noise is bad. I've lived with this Al wiring for about 10 years. I've had plenty of weird crap happen in that time.
Old 05-03-2007, 07:26 AM
Do you think this is what is in that tester he has? Those are neon bulbs.
Old 05-03-2007, 12:37 PM
Banned
snowman's Avatar
I can't come up with a tester that would show the hot./ground fault without also showing another fault as well. Interesting problem.
Old 05-03-2007, 10:13 PM
