MAGA
I actually have done a bit of it, but I hate it (especially ceilings!). I hope my wife does not read this. She can't quite figure out how I can build an airplane from scratch, rebuild engines, paint cars etc, yet I don't seem to know how to do landscaping or remodeling
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Maybe Tim and his wife are looking to adopt an older "couple"
Senior Member
Just paint.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
1996 FJ80. |
Senior Member
I'm chuckling. Because the drywall suggestion is more expensive than you think. You empty the structure. Hang sheets. Mud/tape. Mud. Mud. Mud. Texture. Paint. Notice that it looks like a living room now and so, therefore, new lighting is probably a good idea, maybe a new window. Seal the floor. Sink. $25K and fourteeen months later, you're done. Or just slap two coats of good paint on it, and be done by Sunday at a total cost of $100.
In the shop at Pelican
Supe,
what would you reccommend for exposed studs? My garage was built in 1920 and I'm pretty sure it's redwood paneling. It's dark and dingy. Can I just paint over it? |
Wood paneling in an attached garage is not a good idea. Not fire-proof/resistant. If a car or piece of equipment catches fire, poof...there goes the entire home. At least with drywall, there is some fire resistancy, which will allow time to extinguish or evacuate. Codes requires 5/8" drywall in attached garages in most locales. |
MAGA
I'd still paint it just to "stick it to the man". If I failed to burn down my parent's bare stud garage as a kid, I personally would not be too concerned about painting an existing paneled garage. But that is just me...we already know I like to live "on the edge"
Slumlord
Good point. Especially if you do any welding....
We're not even allowed to mount a circuit breaker panel on plywood anymore, has to be drywall. |
I second the recommendation on using Kilz to primer the paneling. The paneling won't be as fire resistant but if you want to kill smells or stains that stuff is great.
-Jess |
You guys are all wrong. I would install drywall THAN cover it with 4' x 8' FRP panels. They sell it at Loews and other places. You see it used in bathrooms of gas stations and fast food places, kitchens. It's 1/8th" thick and tough. They sell all the trim pieces to finish it off. I installed it in our laundry room and its great.
http://www.sdplastics.com/frpwallpanels.html
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Senior Member
On painting paneling, Jeff, Supe, et al, I originally considered doing just that. We have an area in the livingroom that is paneled w/unfinished drywall underneath. It would have been too big of a mess to pull, tape, etc., so we simply painted it. It looks very good, but there is nothing under the paneling in the garage so it's very wavy and lacks sturdiness. I'm looking for something a bit more solid. Also-Fire rating is a very valid point I did not consider. Thanks for pointing that out. Like many, I have combustables in the garage and things can happen. As it sits, it would go up like tinder. I have some drywall experience and a nice pneumatic Superlift that will work to hoist drywall to the ceiling. The garage is already pretty much cleaned out so all I need to do ( ) is remove the garage door opener and one '8' light. Not too bad. Yeah-the floor will look like crap by comparison once I'm done. Oh well. The slippery slope.
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
(the shotguns)
there is a new drywall out that supposedly is more fire resistant than traditional paper faced drywall. don't recall the name but it was about $2 per sheet more than the normal stuff.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
