Nine9six's Avatar
Oil Spill advice needed
My daily driver spilled oil all over my driveway.
Any recommendations for a quick easy cleanup would be much appreciated.
Thanks in advance...
Paul
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-27-2008, 03:27 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
as for clean up, kitty litter will pick up a bunch quickly, then follow up with brake cleaner for the spots
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-27-2008, 03:30 PM
Kitty litter for the Exxon Valdez portion , and then soak it with Simple Green and wait for rain to remove the stains (if any). I had a van that leaked like a Harley on my driveway, and the Simple Green treatment works great.
Old 12-27-2008, 03:31 PM
crustychief's Avatar
Kitty litter for the Exxon Valdez portion , and then soak it with Simple Green and wait for rain to remove the stains (if any). I had a van that leaked like an old AMF Harley on my driveway, and the Simple Green treatment works great.
Fixed it for ya.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 12-27-2008, 03:49 PM
Yeah you right! I've got a Sporty that's a year older than my 911...only one believes in marking her territory in my garage. Not too much, but still a Harley
Old 12-27-2008, 06:39 PM
Cars & Coffee Killer
legion's Avatar
Get the cheapest kitty litter you can find--it won't have perfumes and "other" ingredients that make it ideal for cat poop but not so great for garage duty.
I got a 25 lb. bag of "Special Kitty" at Wal Mart for under two bucks!
5 liters of VVT fury now
-Chris
Old 12-27-2008, 08:41 PM
mikester's Avatar
Send a message via AIM to mikester
powdered laundry detergent works well too but for a large spill cheap kitty litter is the better bet.
-The Mikester
I heart Boobies
Old 12-27-2008, 08:52 PM
Sultan of Sawzall
rouxroux's Avatar
And for anything left behind after the simple green, you might try a mist of Griot's Garage "Oil & Grease Cleaner" (acually uses microbes to "eat" the oil), then rinse it off. If all else fails, use "Pour & Restore"...I cleaned my garage floors with this prior to etching with muratic acid when I painted them.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 12-27-2008, 08:57 PM
Nine9six's Avatar
Thanks fellas for all your responses...Now I have a bunch of methods to choose from.
Happy New Year!
96 993 C2 (Current)
Old 12-28-2008, 10:41 AM
If all else fails got to the hardware store and get some lacquer thinner and a cheap brush and scrub the spots. That will clean it right up.
Old 12-28-2008, 11:19 AM
Zeke's Avatar
After the kitty, use dry cement and work it well into the pores of the concrete. The more you sweep, the better it works, then vacuum and dispose of responsibly. But, it won't finish up the job perfectly. For that you need the thinner and then a high pressure water hose (not necessarily a pressure washer). But that will get in the ground water if you're not careful. It's a tough call anymore.
Old 12-28-2008, 12:28 PM
Banned
Gasoline removes oil. Cheap, easy.
Old 12-28-2008, 01:09 PM
AutoBahned
RWebb's Avatar
Gasoline removes oil. Cheap, easy, Dangerous!
I'd use a solvent maybe - but then how do you get rid of the solvent/oil mix...
You can toss a small amount of kitty litter in the trash (landfill).
If a lot of oil i is best sent to a recycling/haz waste place - your local parts store and dump (transfer station) can tell you what to do with it.
For the second set of kitty litter - step on it & grind it in with your shoes. Vac up.
milt's cement dust idea sounds like a good one for the finish.
Old 12-28-2008, 01:42 PM
