Un Chien Andalusia
Aerkuld's Avatar
I agree about the electric being a terrible shave.
To answer your question;
BOTH
I usually have a quick shave with the electric in front of the mirror but to shave the side burns then use a blade to shave when I'm in the shower. I used to use the fancy steel handled tri-blade things but have come to discover that a half decent quality disposable does a great job.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 04-25-2009, 06:18 AM
19 years and 17k posts...
azasadny's Avatar
I've used Braun razors since about 1980...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 04-25-2009, 05:54 PM
canna change law physics
red-beard's Avatar
In the past few months, I've started shaving again. I've had a beard for over 20 years. I always shaved my neck, and for the past 5 years, I've kept the beard very short. For interviews, I started shaving again.
Anyway, I'm having a terrible problem with skin irritation, mainly small whiteheads. This happens even when I don't shave very close. I'm thinking about going electric. Part of college, I used a foil shaver, and used a powder stick for lubrication.
James
Red-beard for President, 2020
Old 04-25-2009, 06:06 PM
I shave my face and my head, pretty much everything from the neck up except for my eye brows. I use a Quattro. Great shave and never cut myself. I've used lots of other disposables over the years. The Quattro doesn't shave quite as close as some of the others, but with the other's there was the occasional cut. The Quattro gets much closer than any electric.
I shave in the shower with soap. I use Dr Bonner's liquid Castile soap
Old 04-25-2009, 06:46 PM
Electric, with a little touch up work (dry) with a blade.
I shave once or twice a week, whether I need it or not.
If I'm not meeting clients, the shaver stays parked.
JR
Old 04-25-2009, 06:52 PM
Detached Member
Hugh R's Avatar
Originally Posted by Moses View Post
Always a blade. Always Gillette. I'll use a mug and brush with hot water or Edge gel.
Same here, mug and brush, I have an old brush with virtually no bristle that I take when I travel. Wife bought me a new brush with a drying stand about 5 years ago to replace the one I'd had for probably 20 years. A good bristle brush is, or was about $80. Maybe more now.
Hugh
Old 04-25-2009, 07:45 PM
Control Group
Tobra's Avatar
Originally Posted by afterburn 549 View Post
Never EVER found a electric to do the job..Like a Lawn mower with a dull blade set way too high
yup
Shave post shower, brush and mug with hot water, heavy brass handle for trac II blades that I have had like 20 years. If you rinse your face with cold water afterward, and use cold water to rinse the blade, you will find you irritate your skin much less.
I use a cheap brush that I got at the drugstore, it was made in England though, not China, which sort of surprised me. Seems like the brushes last about 10 years.
Redbeard, that is staph or strep. It is possible you are colonized in your nares(snout) which reshponds to bactroban/mucipiricin ointment up the nose a few times a day. There are those that treat that sort of stuff with clinda or erythromycin too, topically and orally
Old 04-27-2009, 07:31 PM
Parrothead member
VINMAN's Avatar
I prefer to singe the hair off with a propane torch.
Blades for me. Use a Mach 1. Sucks they they are so friggin expensive.
Electrics never worked good for me. I have a beard like a caveman, very tough.
I tried a straight razor once almost slit my neck open. that was the first and last time! although I had a shave with one from an old barber and it was definately the best shave i ever had.
Vinny
Old 04-27-2009, 07:37 PM
Electric for trimming and dry shave with a blade for the rest. I hate foam.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 04-27-2009, 08:21 PM
Banned
Put on a bit of that OXY zit cream stuff after shaving. I used to get bad razor burn until I started using that stuff.
Old 04-27-2009, 08:26 PM
Don Plumley's Avatar
Blade since college. I held off those fancy multi-blade units that seemed to add another blade each year - until I tried one. I use one with five or six blades, whatever Costco has. Amazing. I have very sensitive skin, until I started using Nivea or Clinique shave gel. Made all the difference. When I travel and use the small cans of foam my face gets really irritated.
Don Plumley
M235i
Old 04-27-2009, 10:15 PM
drunk and stupid
HHI944's Avatar
Mach III disposables and barbasol shave cream. On occasion I use that set up to shave my head.
Old 04-27-2009, 10:20 PM
