canna change law physics
because once you place the order, call them and go pick it up in Brenham!
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Wow! 8mm is much cheaper than I thought!
Licensed User
Cleaning cosmoline off of rifles that have been sitting a crate in eastern Europe for 60-70 years irks me a lot more than running corrosive surplus ammo through them. Anyone have an easy solution for that?
Cars & Coffee Killer
WD-40 or a silicon lubricant, then rubbing alcohol to get that off.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
"YOU CANT RACE A CAB."
winchester can thank mauser for their model 70 design. mausers are way cool in my book.
Orange cleaner, from home depot. $7-8/gal
Hilbilly Deluxe
This is cheaper still:
7.92x57 Mauser (8mm) (178 GR.)Sellier & Bellot mfr., 40’s mfg. Berdan primed, corrosive, FMJ, Boat Tail, brass case. 15 rds./box, 600 rds./case. *Priced per case. Price: $158.95 If you have a dealer account it is even cheaper than that (by about $50 ) I like the Yugo stuff better, it shoots a little better for me. Never tried the Romanian, simply because I think steel cased ammo just ain't right. Ammo cases should be brass.Quote:
I just use Mineral spirits and/or Denatured alcohol and elbow grease. |
hair dryer or heat lamp. just warm it up and wipe it off. cosmoline will seep out of the cracks and drip right off.
Man you guys are good. Looks like this is going to be fun! I just have no idea how to mount a scope on this bad boy. I am not a fan of Iron sights above 100 yds.
Plus I just got one of these...lee hand loaders and I have been having a blast reloading twelve gauge!
-Tom '73 911T MFI - in process of being restored '73 911T MFI - bare bones '87 924S - Keep's the Porsche DNA in my system while the 911 is down. aka "Wolf boy" |
Hilbilly Deluxe
accumounts.com makes excellent reproductions of the original type scope mounts, and there are a few different no-gunsmith mounts.
By the way, for Mauser scope mounts, LSR= Long Side Rail, and SSR = Short Side Rail. You can also have a gunsmith drill and tap it for standard scope bases. If you want to do it cheap without modifying the rifle, there are a few inexpensive "scout" type mounts which replace the rear sight and use a pistol scope. You could probably get something like this together for $60 or so. S & K ones are supposed to be pretty good: S & K Scope Mounts Home Page - rifle scope, scope mounts, Insta-Mount, SKulptured Mounts |
emcon, It isn't the original stock, it has been sporterized. Would that affect the mount?
Hilbilly Deluxe
Shouldn't. May make it easier actually, some of the no-gunsmith mounts (the S&K Instamount in particular) require some stock inletting for clearance, I would be much more likely to modify an aftermarket stock than an original military one.
Tom |
