B58/732
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Slippery Slope Victim
Speakman.
We use them in hospital and institutional buildings. Yes, I am a plumber.
MikeČ 1985 M491 |
Formerly reformed
edit: Yes! The Speakman (is it Easyflow?) heads are awesome. edit again: Anystream; that's it. Thank you, David
1968 911P (Paperweight) Last edited by 1968Cayman; 05-05-2010 at 07:30 PM.. |
As a liberator of restrictors in shower heads, its pretty much up to how the shower head looks if you want to pay a lot. Once you get the restrictor out, they all work much better then before Myself, I'm partial to Moens. The new plumbing codes are exhausting. I recently had a master bathroom added to our house the included a air-tub. It required a regulator that would not let the water get much above 100, no mater how you tried with the knobs. I paid the guy to remove it once the inspection was done.
The link I posted earlier is for the Speakman Anystream. You can dial in anything from high flow, low velocity to low flow, high velocity.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Senior Member
What can you do if your water pressure out of the city main line is 40 psi or so? Thats all we have where I live and would love to see 50 or higher.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Normal pressure should be above 60psi. I have put in baths that have around 50 at the end of the line with no regulator. The Hans Ghroe will still work wonders with only 50 psi. I turned the pressure up to 70 at my own home. All the hose bibs are about 120psi. I bypass the regulator because its going outside and I like to blast the local wild lives and keep the coons at bay. I am up in the hills and the pressure is at 120 or so.
Unregistered
$100 for a showerhead? LOL, not in my house ....
I drilled mine to 3/8." Works like a charm. I'm not under the water long, so I don't use that much water. If MrSWD used it she'd drain the water heater.
California is the specialist for those water saving heads... Some hotels have pressure but limited flow, so you get sandblasted instead of showered, to the point it's painful !
At my house we simply removed the extra donut/filter/blocker and it's perfect, I don't think you need a special shower head as much as investigating if there's a block there... Any non-castrated shower head will flow plenty with good water pressure. Last edited by Deschodt; 12-05-2019 at 09:15 AM.. |
As of last year, I think, we can't get a 1.6 GPM shower head anymore. They are restricted even more but they still can be had in rest of the country. The Hans Grohe Club Master is no longer available and many vendors will and can't ship it to CA.
Just find the restrictor, remove or drill it. |
Riiight...
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
