abit off center
72 VW beetle engine rebuild
Well it finally puked. Leaking too much oil and no compression on one cylinder. I will post the rebuild progress here, its been about 30 years since I rebuilt one of these so this should be fun. One question, who is the best supplier for engine parts like gasket kits, big bore cylinder kits etc? I taint going to go crazy with this, I will keep it pretty much stock. The old time suppliers I have used in past were places like bugpatch and Clyde's buggies (CB)
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Formerly reformed
That 'leak' rivals the Gulf spill . . .
1968 911P (Paperweight) |
MAGA
I have not rebuilt one since highschool in the 80's, but back then JC Whitney had the cheapest standard rebuild kits. A quick Google search shows they still sell them starting at $250.
Here is a link that might make for a nice refresher on some various routes to go. Engine Costs - Tech Review - VW Trends Magazine There is/was a place in Toledo called Mini Performance that always has specialized in VW engine machining/building. I assume they are still in business as they machined my 911 heads for me several years ago. If you need some head machining work, they might be of interest to you.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
abit off center
I forgot all about JC Whitney! complete rebuild gasket sets for $14 P&C's big bore $140 forged scat crank $395 worth going all out compared to what I am used to!!! No interest or payment for 90 days too!
abit off center
Progress!
I like those old Bugs. Cool to see you're keeping one on the road. Any hot-rodding planned?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . he and him? |
Burn the fire.
Ditch the Solex and go with duals!
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
MAGA
Brings back a lot of memories.... In highschool, I could have my engine out in 15 minutes flat.
Me, 45 minutes. Memories indeed. I must have dropped 10 of those.
1996 FJ80. |
Good progress and best of luck. Make sure you measure the lifter bores. A friend of mine rebuilt a bug engine twice because of a "knock." Finally, someone told him that his lifters are probably rattling around in the bore. He checked the tolerance and sure enough that was the problem. You can have your bores sleeved really cheap out in CA.
Ya know.....a few beers and you can get a 911 motor in there!...well a few beers and a torch!
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
abit off center
Well I found the problem. I could almost spin #2 cylinder head nuts off by hand. Thats the easy part now I have to machine the case the same for all 4 cylinders and flycut the heads to match. Thats why it was popping and leaking a lot of oil.
Craig,
The last VW engine I built was a 1,776 (cause it was the biggest displacement w/o machining the case), dual carbs and a mild street cam, and a really good balancing job. I really loved that engine in my '65.
Marv Evans '69 911E |
Slippery Slope Victim
CB Performance aka Claudes Buggies.
I've bought tons of good parts from them over the years. They supplied me with parts for an 1835cc, big valve heads, dual 44mm Webers back in the early 80's. I grafted a 901 into my Karmahn Ghia. Very fast car. I raced a '80 911 SC on the FDR here in NYC. They guy could'nt believe I was keeping up with him, especially when we both threw 5th! Great days! Be careful it's another slippery slope
MikeČ 1985 M491 |
Champagne on Beer Budget
totally worthless on the freeway but what a HOOT from stoplight to stoplight! ![]() Although its been 20 years since i've messed with Vdubs...These places I bought from still provide performance and restoration parts. SCAT enterprises Welcome to Scat Enterprises Gene Berg Welcome to GeneBerg.com West Coast Metrics Vintage VW Parts : Volkswagen Parts : Beetle Parts : Bug Parts : Bus Parts : Ghia Parts : Type 3 Parts : Vanagon Parts : VW Carpet : Convertible Parts : VW Interior : VW Restoration : Thing Parts Bugpack Volkswagen Performance Parts and Accessories BUGPACK Good luck! Einar
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
I've done a few of these...
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
VW's.....the gateway drug to Porsches.
MikeČ 1985 M491 |
Senior Member
Loved the old bugs... if I had a bigger garage would get another one!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Leadfoot Geezer
For parts, as well as good tech info, try aircooled.net. Stay away from J.C. Whitney. It might be more cost effective to just replace the piston/cylinder set instead of machining the existing stuff. It's cheap insurance against future problems too. Same for the heads. If you flycut too deeply, you'll raise the compression ratio causing the motor to run hot and invite pre-ignition. It'll also alter the rocker arm geometry which can lead to damaged valve stems. You can compensate for this by shimming the rocker assys or shortening the push rods. If you're gonna open the case, don't be tempted to have the main bearing saddles line bored. This will ruin the case.
If you have a stumble off idle with that motor, replace the mechanical advance distributor with a stock vacuum advance unit. That'll cure it. Here's a link to aircooled.net: VW parts for your Aircooled Volkswagen-Aircooled.Net Aircooled Volkswagen Parts The best air-cooled VW forums, tech help and classifieds can be found here: TheSamba.com :: Volkswagen Classifieds, photos, shows, forums, and information
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '25 BMW 230i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects Last edited by rcooled; 05-17-2010 at 09:24 AM.. |
abit off center
Got a little work done on the case. One head was loose and worked the cylinder into the case so it had to be machined flat again. I took off .020 and will use the same thickness base gasket for this one side. Next is to flycut and rebuild the heads. I ordered all the parts, it only came to about $450 with all new p&c's lifters, oil pump and all the other goodies.
