Looks like you anchored #4 rebar in your slab around the top of the pit. Did you just use a hammer drill to make the holes? Also looks like you don't have any rebar in your floor slab.
Marv Evans
'69 911E
Old 06-12-2010, 10:58 PM
Paul K's Avatar
All:
This job was a major PITA. From finding out that the rock under my garage was basically bedrock to trying to bend rebar by hand- it all sucked. But boy, oil changes will be a breeze now! Here is a pic of the rebar cage that is in the floor;
I used a HilTi tool to drill into the floor, then epoxied the rebar into it- worked pretty well. As for the trackhoe into the wheel barrow- I had two wheel barrows going, and the trailer was only 10' away. Really didn't have any better option.
I haven't backed the 993 over it yet, but will post a pic when I do. Should have lots of room!
Pretty sure I'm going to use aluminum decking to cover the hole- light, maintenance free and plenty strong.
If you're passing through and need an oil change, stop by!
Cheers,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 06-12-2010, 11:57 PM
Rick Lee's Avatar
I don't see how 993 oil changes will be much easier with this setup, as you have to remove the rear right wheel, wheel liner and right side rocker trim for just the large oil filter, even if on a lift. A pit won't make that any different. Gearbox oil changes will be pretty easy though.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 06-13-2010, 12:17 AM
Paul K's Avatar
Agreed, although I don't take the wheel off the 993.
The oil changes on the Land Rover, and especially the Mini, will be much easier. Plus I do oil changes on the in-laws Land Rover & Buick- and their HD trike, which is a real PITA.
'83 SC Coupe SOLD
Old 06-13-2010, 12:24 AM
gt350mike's Avatar
I'm LMAO......seeing the photo of the mini excavator inside your garage was priceless! You've got me thinking how much it would cost me to pay my son to dig a pit for me....his buddies call him the "Resident Mexican" because he's the kid everyone calls when they have a tough job!!!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 06-13-2010, 12:03 PM
not as smart as I think
How will you clean it? My concern of building a pit was/is keeping it clean.
The photos that you put up are awesome. It makes it look like one could do this in an industrious weekend if they so desired. I understand this is probably not the case.
Great job.
1978 911SC stock-SOLD
1985 911 Carrera Stock
Old 06-14-2010, 09:04 AM
Zeke's Avatar
Clean it? How clean? I'd just throw some kitty litter in it and use a vacuum.
Old 06-14-2010, 09:08 AM
vash's Avatar
how many oil changes do you do? enough to make a set of ramps seem like the crappier option?
seems like a super cool project..
poof! gone
Old 06-14-2010, 09:27 AM
As fare as housing codes... I believe what you do on your own property is nobody's business but your own.
Local councils have way too much power in my opinion.
Agreed, aside from the issue of soil and water contamination if you have an oily pit mixing with groundwater. My understanding is that this the primary concern regarding building codes. Lots of people have water in their basement, so a pit can have the same issue.
Old 06-14-2010, 09:43 AM
TSNAPCRACKLEPOP's Avatar
1-800-dig_rite?
flat screen would be nice on that end wall.
nice hubcaps on your ears!
on hot summer days, you can fill it with beer and ice!
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 06-14-2010, 09:45 AM
adrian jaye's Avatar
how do you know he didnt ?
You should have buried a body or two while you were in there. But then maybe you did anyway.
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 06-14-2010, 10:01 AM
Paul K's Avatar
Changing the oil on the MCS is a PITA. Can't drive it up on the ramps, and even after I jacked up all 4 corners and put the wheels on ramps, I could barely fit my fat a$$ under there. Plus when you own a Land Rover, you need to be able to get under it pretty regularly...
Update: Found something to cover the hole up;
I need to do some more work on it (the panels are a really tight fit) but I'm pretty happy with it. If it's dry enough this weekend, I'll paint it with that Rustoleum epoxy floor paint.
I am not going to answer the 'how many bodies' question
Cheers,
Paul.
'83 SC Coupe SOLD
Old 06-14-2010, 09:32 PM
did you add a light or elec socket in there? It could be dark in there. Dragging an ext. cord is a bit*h.
Old 06-14-2010, 10:03 PM
HarryD's Avatar
Paul,
Very nice. I like the idea of the small sections to make them easy to lift and you only need to open what you need.
I would suggest you add some type of built in handles for each section to lift the sections.
I know you can have a separate tool for lift the sections, but permanently attached handles means that Kathryn will not be mad at you for losing them when you need for her to open the pit nor will she drop them on your head.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-14-2010, 10:04 PM
Paul K's Avatar
Seriously considered power, as well as a drain, compressed air, etc. I got 2 of those LED cordless work lights for my birthday (they are really bright!) so I should be good. Plus, after I paint the concrete it will be lighter in there.
Trying to figure out how to do that. Unfortunately the panels are just too big for all 4 of them to fit, so I need to either make the hole bigger (tough) or make the panels smaller (easier but I don't want to weaken them).
I'll keep y'all posted!
Cheers,
Paul.
'83 SC Coupe SOLD
Old 06-14-2010, 11:24 PM
HarryD's Avatar
For your narrow section, why not cut a plate of Aluminium and put a few pieces of channel on the back side to get the height right and add strength.
An alternative is to remove the excess material from the middle and use a channel or H beam to reattach the halves together. Notch the ends so the plate fits flush and provides some support for the break.
Harry
2020 MB E350 4Matic
Old 06-14-2010, 11:51 PM
Model Citizen
herr_oberst's Avatar
Handles could be simple loops of nylon webbing . . .
(here's a thought - next time the kids misbehave (if you have kids,) calmly take 'em out to the garage, point to the pit and make dramatic eye contact.)
Old 06-15-2010, 04:59 AM
I'm a loser, baby.
oregonmon's Avatar
Wow Paul, this is a huge project.
Well done.
1979 911 SC
Old 06-19-2010, 08:14 AM
vash's Avatar
forget handles...get a hooked rod like the utility companies use for pulling up manhole covers. no sense bending over when you dont have to.
i like it. i seem to remember carbon monoxide is denser than air, and will pool in deep pits..so be careful.
poof! gone
Old 06-19-2010, 11:00 AM
1984 Carrera Coupe 3.2
Awesome project Paul-I had a friend in college who serviced his muscle cars much in the same way, but stupidly he dug his pit in the yard next to his house, no reinforcement of any sort. He never had a mishap, but I always worried he was gonna get crushed.
Old 06-19-2010, 02:04 PM
