RETIRED
Joe Bob's Avatar
Winch wiring
Trying to wire in a switch. I have a 30 amp double momentary switch.
Two years ago I was able to figure this out, can't now.....brain is dead I guess.
Anyone got a clue?
The unit was left out in the weather and killed the old switch and the connectors broke in the move....
The thick cable lower left is a ground. Power goes to one or the other solenoid for forward and reverse.....
2012 ML350 3.0 Turbo Diesel
Old 05-18-2011, 04:31 PM
Puny Bird
Mark Henry's Avatar
Those are solenoids, I'd say + goes to that centre nut (heavy gauge wire, direct from battery) between the two small nuts.
The black heavy cable is the ground.
The two small nuts are the two in/out + light gauge wires for the switch. Most likely the switch has a power wire to it and the solenoids ground (triggering the solenoid) when you engage the toggle.
The two outside nuts (in the pic), do they go into the motor? If they do I should be right.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Last edited by Mark Henry; 05-18-2011 at 06:17 PM.. Reason: getting my brain around it
Old 05-18-2011, 04:42 PM
Yea. What he said. Looks like +12V to one solenoid should be fwd. +12V to the other is reverse.
Old 05-18-2011, 05:43 PM
abit off center
cgarr's Avatar
Nice wench!
______________________
Craig
G2Performance
Old 05-18-2011, 06:19 PM
RETIRED
Joe Bob's Avatar
Figured it out, thanks for the help.....I did it right but I had a bad set of wires and connects. I was in a hurry and didn't think.
The winch works, I just need new infrastructure, so to speak.
Old 05-18-2011, 06:49 PM
