-   -   Engine Porn (http://forums.pelicanparts.com/showthread.php?t=622390)
daepp 01-02-2018 02:38 PM
1 of 2 diesel beetles designed by Porsche for VW.
URY914 01-02-2018 03:56 PM
http://forums.pelicanparts.com/uploa...1514937388.jpg
kach22i 01-03-2018 07:18 PM
August 14, 2017
Singer creates 500-hp air-cooled 964 engine with Williams and Hans Mezger
Porsche 964 reimagined by Singer with 4.0-liter 500-hp air-cooled engine
http://forums.pelicanparts.com/uploa...1515035827.jpg
Singer's new engine upgrade, a naturally aspired 4.0-liter air-cooled six-cylinder with many upgrades, is a 500-hp technological marvel. Photo by Singer
pavulon 01-13-2018 06:37 AM
http://forums.pelicanparts.com/uploa...1515854009.jpg
Was able to purchase a new C5R block and callies crank this fall. The $$/power equation of the LS series of engines and the performance of C5/6 vettes makes other endeavors look questionable.
sc_rufctr 01-13-2018 06:51 AM
http://forums.pelicanparts.com/uploa...1515855084.jpg
http://forums.pelicanparts.com/uploa...1515855104.jpg
kach22i 01-16-2018 05:46 AM
https://seconddaily.com/daily-gear/1967-volvo-p1800s-4-sp-manual-w-od/
http://forums.pelicanparts.com/uploa...1516110344.jpg
bkreigsr 01-16-2018 08:54 AM
Originally Posted by URY914 (Post 9870023)
uuhhh - cancel the order for the new tires.......
daepp 01-20-2018 12:06 PM
Here's a new one on me - the Ford GAA.
WWII era all aluminum flat-plane crank V8!
DOHC (4 shaft driven cams), 32v, dual carbed, 1100cid, dual plug, and dual magneto.
Ford rated it at around 500HP at 2600 rpm and roughly 28000 units were produced, mostly for the (crappy) Sherman Tank. in full military dress it weighed approx 1000lbs; today, many versions have been restored and at around 675 lbs can be made to produce 2000 reliable HP.
As delivered for the military:
http://forums.pelicanparts.com/uploa...1516478523.JPG
Various modifieds:
http://forums.pelicanparts.com/uploa...1516478523.jpg
sc_rufctr 01-20-2018 05:43 PM
"(crappy) Sherman Tank."? :confused:
Do you know how many Sherman Tanks and variations were produced over the years?
And how many nations used them?
http://forums.pelicanparts.com/uploa...1516499014.jpg
GH85Carrera 01-20-2018 06:51 PM
https://uploads.tapatalk-cdn.com/201...c3e741a89c.jpg
URY914 01-20-2018 06:55 PM
http://forums.pelicanparts.com/uploa...1516503311.jpg
http://forums.pelicanparts.com/uploa...1516503359.jpg
URY914 01-20-2018 06:57 PM
http://forums.pelicanparts.com/uploa...1516503466.jpg
daepp 01-21-2018 08:12 AM
Chrysler A57
"Five Chrysler 250.6 cu in (4.1 L) (bore 3.4375 in, stroke 4.5 in) flat-head inline six cylinder engines were arranged around a central shaft, producing a unique 30-cylinder 21-litre (1,253 cu in) engine in a relatively compact but heavy package. The crankshafts were fitted with gears, which drove a sun gear arrangement. With iron block and head,[1] it featured Carter TD-1 carburetors and 6.2:1 compression ratio, for an output of 370 hp (280 kW) at 2400 rpm."
Interesting, but with dismal output:
http://forums.pelicanparts.com/uploa...1516551082.jpg
I guess we were so unprepared for war, so that were open to anything...
kach22i 01-21-2018 08:59 AM
W engine
https://en.wikipedia.org/wiki/W_engine
http://forums.pelicanparts.com/uploa...1516553883.JPG
http://forums.pelicanparts.com/uploa...1516553883.jpg
A W engine is a type of reciprocating engine arranged with its cylinders in a configuration in which the cylinder banks resemble the letter W, in the same way those of a V engine resemble the letter V.
https://upload.wikimedia.org/wikiped...gree_angle.gif
kach22i 01-21-2018 09:03 AM
The modern "four-bank" design
http://forums.pelicanparts.com/uploa...1516554120.jpg
A W16 engine from the Bugatti Veyron
kach22i 01-21-2018 09:06 AM
U engine
https://en.wikipedia.org/wiki/U_engine
http://forums.pelicanparts.com/uploa...1516554359.jpg
Bugatti U-16
https://upload.wikimedia.org/wikiped...b/U-Engine.gif
Racerbvd 01-21-2018 01:25 PM
http://forums.pelicanparts.com/uploa...1516569906.jpg
Racerbvd 01-21-2018 01:26 PM
http://forums.pelicanparts.com/uploa...1516569951.jpg
Racerbvd 01-21-2018 01:27 PM
http://forums.pelicanparts.com/uploa...1516570007.jpg
