almost full length plywood door and all. No warp
Old 11-12-2014, 12:00 AM
Drawers down below, hanging up top and a big hamper on the right side. this is my own house, master bath closet
Old 11-12-2014, 12:02 AM
Those look great.
I am leaning towards plywood boxes. But I am conflicted. Too many options, each with pros and cons.
Old 11-12-2014, 09:43 AM
You do not have permissi
john70t's Avatar
There are many types of plywood: Plywood: Types and Uses - Fundamentals Of Woodworking
Old 11-12-2014, 10:51 AM
závodník 'X'
intakexhaust's Avatar
What kind of style are you after? Overlay or recessed?
Typically use a hardwood for the face frames, glue and pocket screw construction. The pocket screw jigs cost are nominal. Work like a charm and fast.
Build the boxes and shelves from cabinet grade ply. I'll skip all the details for build but you might check out the numerous sites to guide you along. Skip the biscuits. Glue and screw / pocket.
Doors and drawer fronts vary greatly but for discussion of wanting stability under temperatures and humidity, go for the MDF. Machines clean but harder on the blades or router bits. Paint spray with a two part urethane. If you want a wood grain, stay with the MDF but add the laminate by iron heat or veneer. The veneer process will take quite a bit more of your time and added equipment (ie: vacuum bag, vac pump, glue-up, etc.). Then you have the paint or stain process. For another chapter..
Unlimited sources for shelf, drawere guides, hinges and type, etc. and will take lots of pre-planning for whatever you select.
Old 11-12-2014, 02:23 PM
Originally Posted by 1990C4S View Post
Those look great.
Looking at that picture, I build it out of Maple plywood and paint everything. It ain't gonna to twist on ya. Dado, rabbet with some screw are your friends. Fill the screw hold on the outside with bondo and spray paint away. personally I rabbet a center shelf somewhere to make sure its stable so it would warp. Plus, its acts as a stop where the top and bottom doors joint. Shop grade Maple, classic core paints best IMO beside MDF.
Old 11-12-2014, 04:08 PM
It's under way...
The drawer in the photo is just a mock-up for scale....
Old 02-04-2015, 09:13 AM
