Originally Posted by recycled sixtie View Post
You must be Canadian or non-American!It's okay. It took me a while to figure out too. CCW is related too.There is a wide array of words, acronyms on this forum that takes a while to understand.......
Yes., Canadian, seems we don't know about these lead delivery systems. Now what is CCW?? Some might not believe this, but I don't know one person who owns a gun. I might join the A.A.A.A.
Old 12-14-2012, 10:19 AM
A.A.A.A.= anti acronym association of america (northern chapter)
Old 12-14-2012, 10:33 AM
Kim,
Did you reset the breaker by turning it off, and then back to the on position?
If you just try to push the breaker to the on position, I dont't think it will work, must be shut off and then back on.
You should be able to call your local Building Permit government office and find out if you need a permit. To me, it seems kind of odd that one is needed.
Craig
77 Ice Green 911s w/3.0
Old 12-14-2012, 12:12 PM
canna change law physics
red-beard's Avatar
Originally Posted by LubeMaster77 View Post
TABS coined the phrase to use as a cover so the feds wouldn't be able to get to his cache info...
Actually, it wasn't Tabs. Tabs actually collects spoons, or did. But he was also known for being a collector/former FFL. Someone here mistook his reference to spoons as being a code word for firearm.
And then it just kind of stuck.
Me? I think I need a ladle
James
Red-beard for President, 2020
Old 12-14-2012, 12:47 PM
Eric Coffey's Avatar
Originally Posted by 12own911 View Post
Here's my dumb question. I blew a fuse at home and tried to reset it at the breaker but it will not reset, what's my next step? Keep in mind that I am a girl without skills on my house and have no man to help. You all are my men and women who know things... and can assist me. Help please.
Sometimes a breaker can become loose on the panel, resulting in random/continious trips. If you can take the panel faceplate off (ususally just 1 or 2 screws), you should be able to remove and replace the breaker to make sure it's properly seated. I can't imagine that replacing a breaker would require a permit though.
Old 12-14-2012, 12:55 PM
Non Compos Mentis
The only dumb question is one that is not asked.
There may not be any stupid questions, but there sure are a lot of inquisitive idiots....
Old 12-14-2012, 02:36 PM
craigster59's Avatar
Kim, you do not need a permit to change a breaker AFAIK. If the electrician says you do, find another one who will take care of it. Seriously, it's a fifteen minute job max, a little tougher than changing a lightbulb. He should install a new breaker and test the circuit to make sure there aren't any shorts.
Old 12-14-2012, 02:50 PM
Double Trouble
targa911S's Avatar
what he said^^^^^
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 12-14-2012, 04:41 PM
GWN7's Avatar
A spoon is a device used to feed yourself. A CCW is a permit to allow you to Conceal Carry Weapon. Called many different things in different parts of the country.
Kim- breakers can get weak over time and won't reset properly. You must know someone who can change it for you? Someone you work with? Their husband or second cousin?
The tools needed to change a breaker are a flashlight and a screwdriver. Go look in the panel and find out who the manufacture of the panel is. Write it down. Identify the breaker that is thrown. What number is on it? 15, 20 or 30? That is the amperage of the breaker. Write that down. And any other numbers you see on the panel. Go to Big Box stores electrical dept. Flash your baby blues ( I assume since your blond you have blue eyes ) at whom is working there and ask them for the breaker (info written on paper). Go home and save the bill incase Big Box Person was a idiot and sold you wrong breaker.
Go to ele panel and shut off main breaker (big switch usually at top of panel). Now turn on flashlight. Use screwdriver to remove screws from cover panel. This exposes the breakers. Pull blown breaker out of panel (they usually have to be pulled toward the same side of the panel box they are located on to remove. Unscrew wire attached to breaker and reattach same wire to new breaker. Replace breaker in panel. Screw panel cover back on. Turn back on main breaker. Go reset your clocks and make popcorn.
Bunch of old cars
Old 12-15-2012, 12:11 AM
Vafri
Do you mean the breaker resets and then pops again.....or.....do you mean it will not even reset?
If you mean it will not reset, make sure to pull the switch all the way over to the OFF side, that resets it, then switch it ON
Old 12-15-2012, 02:10 AM
No Banner
Originally Posted by GWN7 View Post
...Kim- breakers can get weak over time and won't reset properly. You must know someone who can change it for you? Someone you work with? Their husband or second cousin?
+1...excellent advice above imo, just make sure you do what I highlighted in red and you'll be fine!
Old 12-15-2012, 03:40 AM
Former Drama Queen...
12own911's Avatar
Send a message via Yahoo to 12own911
Hi guys, it was the main breaker that was dying. Everything I read said that if it was the main breaker call an electrician. The electrician said that the original installation of the outdoor panel was put in badly. He had to shut off one of the lines from the electric company. Permits received and work to replace the panel is scheduled for Monday after the the 'main" man comes and puts of the thingy on the panel box. It's expensive but I believe it will be worth it in the end.
Thanks for all of your support. The braintrust at its best.
~ Kim (KDOLL2)
It is better to cry in a Porsche then in my Vue...
Old 12-15-2012, 02:41 PM
Retired and enjoying life
azasadny's Avatar
Kim, I'm glad you had an electrician work on this for you. Your home and piece of mind is well worth the cost to get it fixed ... right!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 12-15-2012, 02:50 PM
GWN7's Avatar
Main breaker replacement requires electrican and permit as the power needs to be turned off at the poleand yes it can be expensive. Glad to hear you figured out what was wrong.
Bunch of old cars
Old 12-15-2012, 02:59 PM
Wow, here in Ohio we had an electrician replace the whole box and install 200 amp service. We only needed to have the electric company come out to run the new feed line, but no permits were required (or asked about).
Old 12-15-2012, 04:46 PM
Make Bruins Great Again
Por_sha911's Avatar
Its the secret code word for the boys tree fort to be cool.
Joe
Old 12-15-2012, 05:02 PM
