Nascar Race Engine
Finally got everything back from the machine shop, assembly begins
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Unregistered
Dammm, how big are those intake valves?
I'm surprised they run H-beam rods 'cause of the windage, unless maybe it's a dry sump ....... |
MAGA
I would have thought that engine would have domed rather than dished pistons for higher compression ratio. What kind of rpm will it be spinning and what kind of horsepower is this engine going to produce?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Just thinking out loud
I imagine that the lift and duration of the cam necessitates a set of pistons that are dished to the exact shape of the heads. Otherwise, it would be an interference engine.
83 944 91 FJ80 84 Ram Charger (now gone) |
Should make just over 700HP, will post dyne results. The rev limiter will be set at 8200
check the combustion chamber sizes, basically just valve pockets. Domed pistons disrupts airflow and the burn. The piston reliefs are not just for valve clearance, it is effectively the combustion chamber. Last edited by romad; 05-23-2013 at 10:31 AM.. |
Now I know why I get 2-2.5 MPG
Driver
Just remember, assembly is the reverse of disassembly.
Well, unless you blew up the motor on the track. Then I hope you have some sort of shop manual.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
These are so simple compared to what I'm used ie Porsche Engines, my wrench is a V8 guru. This a whole new beast, Block, Crank, Pistons, Rods, Valves, Springs act
Unregistered
LOL, last time I built a full race v8 I put in pistons that looked like this:
![]() Later, I bolted on a supercharger and changed the pistons to something more like this:
Eva
This AWESOMENESS is being dropped in what...
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Well sammy, not all engines are hemi's.
I stopped by coupe's shop yesterday and saw what you see. In fact, I think I missed the picture session by minutes. The Ford block looks small and compact to me. I liked what I saw. They have installed roller bearings on the camshaft. It spins like a top with no lifters. Love to be there when they fire that puppy. |
Unregistered
That's a good thing. No way would mine last 500 miles.
I'd love to be able to take an older stock car and strip the weight out of it, what are they stock, 3200? Iffn you could get it down under 2500# with all that HP it'd be downright scary. Er. Scary-er. Prolly wouldn't be legal tho. |
If you need an extra hand I can be had cheap while I'm working to find work. I do know how to use a torque wrench as well as how to identify a grade 8 bolt.
Jim
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
You would need a sawzall to cut out the rollcage. there's not much in dead weight on these cars.
Unregistered
Guess that's why they can walk away from them 200 mph crashes. Guess that's also why those 1300# F1 cars cost $20 mil each. |
And if you could provide at least a partial list of items that could be safely removed to achieve an 800# redcution, I'd like to look. But if you are telling us that aluminum can be substituted for steel, well that's not news. |
