I'm a Country Member
4000+ meters.
Stuart War crimes will be prosecuted. War criminals will be punished. And it will be no defense to say, 'I was just following orders.' George W. Bush |
So twice this depth would be very challenging for an aluminum tube....
"The pressure increases about one atmosphere for every 10 meters of water depth. At a depth of 5,000 meters the pressure will be approximately 500 atmospheres or 500 times greater than the pressure at sea level. That's a lot of pressure."
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
Almost Banned Once
"Our" Prime Minister "Tony BlAAbbott" needs to pay better attention during his briefings
![]() From CNN. The possible signal heard Thursday by airplane is unlikely to be related to Flight 370, the head of the Australian search effort said. That signal would have been the fifth signal heard, after four were heard by a pinger locator towed by a search ship. Separately, Australian Prime Minister Tony Abbott told reporters in China "we are very confident the signals are from the black box." It was unclear if Abbott was referring to the four earlier signals, to the possible fifth signal or to all of the signals. Lots of things become unclear when Tony speaks...
- Peter |
Virginia Rocks!
Sugar Scoops Rule :)
Not necessarily crushed into oblivion, but yes, 'crush depth' or something siimilar how submariners refer to it. When I was in the Navy and flying S-3's (anti-sub), I remember our simulator had a recording of a sub being crushed after we would succesfully torpedo it in training. Several Tom Clancy novels have submarine sinkings in them where the shooters hear the sub being crushed on their acoustic gear.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Objects like broken wreckage would sink to the bottom relatively unaltered. It is not like it is being run over by a giant steam roller. Anywhere that water can seep into an airspace it will fill the inside and push out at the same pressure as the water pushing in. Things like spent oxygen bottles will be squashed flat if they were well sealed but a section of broken fuselage would remain intact. If the entire cabin of the aircraft remained air tight, it would probably float and not sink anyway. However, if it were somehow (very unlikely) dragged down under and remain completely sealed it would reach a depth where it would collapse catastrophically.
When I was working in deep sea seismic research, we would sink ocean-bottom seismometer units to the ocean floor where they would remain for a week or so recording data before detaching from their anchor and bobbing to the surface to be retrieved. The delicate electronics was enclosed in a crush resistant aluminum sphere. For fun we attached a Styrofoam coffee cup to one of the OBS before it was deployed. When it was retrieved, the cup was a miniature replica. The gas in each of the foam cells was compressed until it dissolved through the foam and into the water leaving behind only a tiny plastic blob for each of the cells, still attached to each other in their original shape. Only thing, the shape was reduced in size. |
good point, anything that's compressible (like a submarine or a sytrofoam cup - that's pretty cool)will collapse...wreckage wouldn't. The Titanic still looks relatively intact, but broken, sitting way down there.
Did you get the memo?
That assumes that the fuselage is airtight, which is incorrect. A number of the fuselage seals on a pressurized airplane are inflatable and bleed air driven, without the engines running they would leak down. Further, pressurized fuselages have an acceptable leak rate, none of them are 100% sealed. Even if you were able to gently land an airplane on the water (Hudson River), it would eventually fill with water and sink.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Registered ConfUser
But...in any case, there is plenty of stuff that would float and given the amount of time, it is still interesting that not a single piece of floating debris has been identified. That is almost unexplainable at this point.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
While I'm not sure how fast the ocean currents are down there, I have read that some reach 75 miles a day. So the plane went down roughly 30 days ago. 30 X 75 = 2250 miles. It's the start of the winter season down there and I'm sure that some storms have happened. Very light materials could get blown a lot further distance than that. So if the area of the debris was as long as it could be wide 2250 X 2250 miles that is a huge area to spot a 2' X 2' seat cushion floating in. There is also floating patches of debris in each ocean that traps more junk every day. The one in the Pacific ocean is reported to be the size of Texas.
Bunch of old cars
Chris '75 911s Targa |
Dog-faced pony soldier
Zactly - that's the whole premise of theoretical super-deep dive suits where the diver could "breathe" an oxygen-carrying liquid (perfluorocarbon-based). The theory is that the liquid (incompressible) inside a suit (which the diver could also breathe) would help to equalize the pressure inside and outside, giving much better resistance to crushing. I've no idea where the research is on that - just that it's something that was being looked at about 15-20 years ago with implications for super-deep diving and high-G load suits. Crazy stuff.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Almost Banned Once
- Peter |
Almost Banned Once
I couldn't agree more. That's why I think the plane is not there at all. Meanwhile the search goes on. Hopefully at some point we'll all know what happened.
- Peter |
CVR tells you why it happened. But yeah, (as already stated by another poster) 2 hours of windnoise and automated alarms will be of limited use.
(As for) Michael Moore:Calling that lying liberal POS propaganda a documentary is like calling PARF the library of congress. I knew it would happen, just not so soon........... |
FUSHIGI
Started wondering about this and quickly came the conclusion that it's a non-starter. Problems that must have been considered were lungs and vocal chords REALLY don't like foreign fluids, how are air-filled cavities (sinuses...) going to be filled with fluids, how are all these fluids not going to become a giant medium for infection, how will anyone see without some gas filled space in front of the eyes....
First, if the plane went into the water as most think, any debris field will be much more restricted in size than if the plane came apart in the air. Second, there was a force five typhoon within two days of the assumed crash, in the exact area where the pings are located. Any floating debris would have been widely scattered by that one event alone. Third, the area where the pings were located was not even searched until over three weeks had passed. Any debris floating after the crash would have had plenty of time to float far from the site and, possibly sink if it was susceptible to water absorption. Fourth, it's possible any debris was very small to begin with and floating with little exposure above the surface making it very difficult to see even if right on top of it. Fifth, the great unknown, it's possible that the plane went down relatively intact with very little debris left behind. Add that to the elements listed above, and the likelihood of finding it right away is very small. Finally, keep in mind this disappearance is unprecedented in its lack of information as to location. The crash it is most often compared with is AF477, and in that case, the general location of the crash was known, and a debris field was located. I'm certainly no expert, but given the circumstances of this particular incident, I don't find it especially mysterious that no debris has been found yet, and I'm convinced some debris will eventually be identified, probably from some random discovery by an unofficial search entity.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 04-12-2014 at 09:17 AM.. |
If the aircraft ran out of fuel at say 25,000ft without pilot input would it have any glide slope or would it nose dive? I remember being amazed at the tiny impact zone on the WTC from an aircraft hitting at 500mph.
I also did the test of the Downed Aviator Locator System (DALS) in the late '80's. The system basically used the PRC-90 radio we all carry in our survival vests as a beacon and allowed an aircraft equipped with DALS to "hone" in on the signal and fly on top. DALS was developed because of the fact that airborne search assets routinely flew right over survivors in the water and failed to spot them. I flew hundreds of simulated rescues using DALS equipment. We started with just having the guy sit in a large boat and emit...worked great. We then put guys in survival rafts in the Chesapeake, MUCH harder to spot, even knowing where to look. We then put the guy in the water with just his floatation gear...on certain heading, sun angles, etc., even knowing where to look, it was difficult, very difficult to spot the person. That and very little in a jet liner that is visual floats for long...combined with an open ocean search without a define CEP and there is no mystery in the lack of debris, at least to me. Something will come ashore.
1996 FJ80. Last edited by Seahawk; 04-12-2014 at 10:33 AM.. |
But I don't know whether there are overrides in a Boeing 777's automated flight controls. Last edited by Rinty; 04-12-2014 at 05:35 PM.. |
