GFCC
Jeff's Avatar
Thoughts on this lift please
After a day of working on cars my back and knees are barking pretty loud. So, I'm thinking of getting a lift for my garage. I don't wrench for a living, just a weekend warrior.
After reading all the threads I could on the subject I thought a 4 post lift would be the one I would get, then I ran across this...
Dannmar MaxJax 2 Post Portable Lift-DMJ-6 at The Home Depot
It can be moved out of the way.
Anyone have personal experience with this lift? Opinions welcome as well.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 08-22-2014, 08:06 AM
UnRegistered User
billybek's Avatar
I think Costco had them for a bit cheaper price than HD.
I looked one of these installed in a small garage. The man that owned it was having trouble getting the car back down as it wouldn't descend evenly. As I recall the factory help line was great getting him parts and assistance right away.
One of the factors (I did research these before buying a lift) was the pad thickness and bolting of the units to the floor is critical. Great for a low ceiling garage and for moving out of the way.
The reason I didn't get one was that I found a used Snap-on scissor lift on Kijiji.
YMMV.
Bill K.
Old 08-22-2014, 08:18 AM
The only experience I have with lifts, other than the kind you find in gas station garages (big single cylinder), is with this one that my brother has:
That two post you linked to looks scary to me, personally. Not having the posts tied together some way does not look all that safe. I would recommend you bolt it to the ground when using it.
The four poster my brother has works well, even though it isn't bolted down. He had plans on moving it, but it's pretty much stayed put where it was assembled. He's had a Suburban up on it so it is robust.
Scott
'78 SC mit Sportomatic - Sold
Old 08-22-2014, 08:22 AM
MBAtarga's Avatar
Lots of discussion/threads on lifts over on Garage Journal forum...
Mark
'83 SC Targa - since 5/5/2001
Old 08-22-2014, 08:55 AM
Originally Posted by Scott Douglas View Post
I dig the car
Old 08-22-2014, 10:44 AM
Model Citizen
herr_oberst's Avatar
Nice ramps.
Old 08-22-2014, 11:03 AM
Jeff, you are welcome to come check out my snapon scissor lift if you'd like. Just to lay eyes on it and see how it works. I really like it, but it does restrict access some, however, it also stores under the car.
Old 08-22-2014, 11:10 AM
MBAtarga's Avatar
I just realized- there is a Bendpak lift group purchase thread that was started just the other day on the garage journal site. You might want to consider one of their models for comparison.
BendPak 4 Post / 2 Post Lift Group Buy - The Garage Journal Board
Mark
Old 08-22-2014, 11:26 AM
Touque's Avatar
I have the MaxJax and bought it from Garage Equipment Supply when it was on sale. I'm very happy with it. I had a hell of a time getting the compression anchors to stay in the holes though but I think I rounded the holes quite a bit with a dull bit. I eventually went to the glue-in epoxy anchors and they held with no issue.
It doesn't go 'that' high but it works great. I tend to keep both of the columns always in and park between them and only move one if i need extra space. It's not perfect but good for my garage that doesn't have an extremely high ceiling height.
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 08-22-2014, 11:38 AM
GFCC
Jeff's Avatar
Scott it does bolt to the ground but I agree, I would love to see the 2 posts connected somehow.
How well does your 4 post hold up to the weather?
Ideally, a four post would be my first choice. It would allow me the option to stand while working under the car. The only draw back would be there would be room for another car in my garage
MBAtarga, thanks for the Garage Journal direction/ group buy thread.
Sid, would love to check out your set up. How high does your lift go? In what way does it restrict access?
Touque, Thanks for the first hand knowledge.
The ability to move the MaxJax out of the way is a huge bonus. It also looks as if I wouldn't have to rearrange the garage door configurations.
Four post, as mentioned before, would be ideal it would entail moving garage door tracks, etc.
The other option is to pour a slab and put it on the side yard.
I like the small foot print of the scissor jacks. Some of them are mobile but I would guess they are way too heavy to tilt up against a wall.
Any brands you would recommend / stay away from?
Jeff
Old 08-22-2014, 01:38 PM
Jeff. My scissor weighs about 900lbs. It has wheels and the pump makes a dolly, so you can roll it around a bit, but no you aren't going to store it anywhere but on the ground.
Mine will go 4 ft up, but the car hits the ceiling before it gets that high.
Depending on ground clearance, you have to drive up on planks, or if you know it's permanent you can make a 6" deep pit and place the lift in there.
If I owned this house I would put it in a pit, but for now the ramps aren't bad. I need to find their permanent spot and bolt them down.
Old 08-22-2014, 01:46 PM
GFCC
Jeff's Avatar
Wow! That goes much higher than I suspected!
Love the bug!!!
You say the pump is used as a dolly so you could move it from bay to bay, correct?
I need to come check it out.
Does the flat lifting surface interfere with drive shafts on 4wd vehicles?
Jeff
Old 08-22-2014, 02:24 PM
Yes it has wheels. It's tricky to move it but it could be done yes. If you ever get over to Gilbert let me know.
I got that lift on craigslist in OKC for like 1k...
Old 08-22-2014, 02:28 PM
Bill Douglas's Avatar
I've recently bought one that looks like Sidney's and wish I'd bought one years ago. Safe, quick, easy....
Old 08-22-2014, 02:59 PM
Jeff, the lift shown is my brother's and has been outside for at least 5 yrs. It took me a while to convince him he really needed one. =;>)
Steve - It's got a 454 in it. =:>O
Scott
Old 08-22-2014, 06:00 PM
