There is a ton of aftermarket trailer brake kits available. https://www.google.com/search?q=aftermarket+trailer+brakes&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US fficial&client=firefox-aThe important thing is that she learn how to set the in truck/car resistance for the brakes. Seriously, a lot of folks don't take the time to learn you can adjust the amount of brake play between the vehicle and the trailer. I won't tow much of a trailer or load without trailer brakes and in cab controls. With the right hand control in cab, if the trailer begins to oscillate for any reason, she can gently brake the trailer independent of the car brakes...brings it right back every time. Concerning the OP, the only time I have had a trailer off the ball in over forty years of towing was when it I had an empty trailer going to pick up a tractor I had repaired at the local dealer. I forgot to lock the hitch. Thank god I didn't forget the chains. The trailer came off over a bump when I was going about 25MPH. I dodged one. I also have put the automatic brake device on my trailers: If they get off the ball and the chains break the trailer brakes automatically come on. I treat, with the one notable exception, towing as an emergency about to happen.
1996 FJ80. |
Team California
A real trailer brake with controller is definitely the best set-up but right now she is towing this little trailer around with no brakes at all and I'm wondering if there is something in between that and optimum that is easy?
Denis |
Make it work holistically with the truck/car brakes, that is the only way. Depending on what she is driving, it could be very simple.
1996 FJ80. |
Old dog....new tricks..... |
Non Compos Mentis
The carabiners I got are stronger than the safety chains to which they are attached. |
River Rat
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
Dog-faced pony soldier
Lucky it didn't get him in the back of the head - that'd ruin his whole day!
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
(the shotguns)
crossing an intersection on a 2 lane highway (thank goodness going very slow) pulling the 23' center console and my son says 'dad the boat is getting farther away'.
clamp thingy had been pushed up by the ball and never engaged. wire safety lines did zippo to stop it. ended well though as I stopped the truck and let the trailer hit it.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Parrothead member
That's crazy. No way I would ever use a carabiner made for rope work, climbing , rapelling, etc..,. They are not designed to use as a chain connection point, or to take that type of shock load. Especially an aluminum one. I only use shackles like the ones URY posted.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
