Cars & Coffee Killer
legion's Avatar
Kraft Facing
I'm insulating my walkout basement walls. Most of the studs are 16" apart, but in a few places they are narrower--presumably to bear the load of the house above. The studs are as narrow as 2-9" apart in places. I had to cut rolls of insulation vertically for the wider (but still less than 16") non-standard spaces, meaning I could only staple one sid. I put loose insulation in the 2" gaps.
In the middle of this project, the decision was made to move back to Illinois. I now want to cover all of these non-standard widths with "kraft facing" cut and stapled all the way around so it looks presentable and matches the rolls of kraft-faced insulation that cover the majority of the basement walls. I just need the "kraft facing", not the attached insulation. Any ideas on where I can get it?
5 liters of VVT fury now
-Chris
Old 03-25-2015, 07:15 AM
I see you
flatbutt's Avatar
I've never seen any such like Chris. How about a roll of butchers paper?
Old 03-25-2015, 07:20 AM
wdfifteen's Avatar
Lowes has it
Shop Trimaco 18-in x 180-ft Non-Adhesive Craft at Lowes.com
Old 03-25-2015, 08:17 AM
legion's Avatar
Thanks!
-Chris
Old 03-25-2015, 08:27 AM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
Moving back to Illinois so soon?
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 03-25-2015, 08:29 AM
MRM MRM is offline
Any builder supply store has it. Make sure you use the right stuff, though. Some kraft paper is plain but most has a coating on it to act as a vapor or moisture barrier in varying degrees of permeability depending on the coating. You probably want something that breaths but blocks moisture. If you describe your situation to the building supply sales person they'll fix you up with what you need.
MRM 1994 Carrera
Old 03-25-2015, 08:34 AM
I don't think a roll of clear plastic sheeting would work for the reason of not allowing breathability, I sceond that you should ask someone at Lowes/Home Depot about what is best.
Old 03-25-2015, 08:38 AM
legion's Avatar
Thanks guys! The stuff wdfifteen posted is in stock at my local store, so I can inspect it and make sure it is what I want.
-Chris
Old 03-25-2015, 08:50 AM
