electric kitchen range burner question
Yesterday my wife noticed that the main large burner on our kitchen range didn't seem to be working correctly. What she noticed is when the temp setting was set on low that the burner was very hot. Does this sound like the burner going bad or the temp control ? Can I take one of the other burners even though they are different size and plug into where the bad burner is to see if it is the burner that is bad ? I'm trying to figure out how to trouble shoot the issue.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Used Up User
It sounds like the controller. Range elements are just a resistive load - a curly wire inside the metal casing. When they go south, they usually blow a hole. If you have a multimeter, you can easily check the element.
See Test Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
We popped out the suspect element and replaced it with the other element that is the same size and it worked. So we took the suspect element and placed it in the spot we just removed the other element from...........both elements working properly ! Electron voodoo ? We'll see if the self healing lasts.
. Now swap 'em back and they will probably still be fine....VooDoo or hoodoo? I dunno, but that's not unusual based upon my past experiences...
You do not have permissi
It's a good idea to get them red hot once in a while to burn off oil splatter.
I once saw several burners disintegrate into a giant fountain of molten sparks across the kitchen. Not good.
Meanwhile other things are still happening. |
