least common denominator
So you guys think I should cancel the engine swap I have scheduled at Walmart?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
If it's been well taken care of in the past it could've done the whole trip on that BEFORE change easy then.
Scott '78 SC mit Sportomatic - Sold |
My daughter has an 08 Civic. She takes it to the Honda dealer they charge $14 no appt needed
they use a Honda filter Why would you go to Walmart? or jiffy lube or whatever
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R |
What is weird is that they are the ones who will have to remove the lugs and filters and drain bolts the next time. So, you'd think they'd learn fast.
Did you guys dealing with stuck oil filters try to remove when hot? I've noticed that gives much easier.
1986 Bosch Icon Wipers coupe. |
Banned
My new '12 Duc. Hyper had to have 3 Ducati oil filters in order to stop the weeping on my first dealer oil change.
I see you
Huh, I've never done an oil change when cold so I can't say.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
They put RTV on the drainplug wtf? I guess they were going to make sure it didn't come back for the 3rd time
I dont particularly like the value propositon of changing oil myself but I don't trust these quicky type places for anything. I even bring wheels to they tire shop. The pita is worth not have to deal with a twisted off stud every now and then. I am guilty of using fram filters sometimes on my pedestrian cars. Am I a terrible person. I sorta like the textured end so they can be unscrewed without tools.
84 930 18 Cayman GTS |
They didn't want to invest in another drain plug washer so used the RTV instead.
In my case, it was warm but not hot when I tried to undo it. I really am at a loss as to how they can get it so tight without any signs of damage from a wrench on the filter. And that $14 oil change at the dealer is pretty good, I just wonder what kind of oil they're putting in at that price.
Scott '78 SC mit Sportomatic - Sold Last edited by Scott Douglas; 01-14-2016 at 09:25 AM.. |
It wouldn't even work....that's the crazy part.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
1990C4S - I forgot a key word in my post.... Washer....the rtv would keep it from dripping which most washers will do if used twice unless torqued really tight. DAHIK.
Have been using fram oil filters for the last 20 yrs or more...never any problem.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
The "Fram filters are junk and will grenade your motor" mantra seems to be one of those internet things that won't die--and it is always a "buddy", or "my uncle" or friend of a friend who had some catastrophic engine failure due to a Fram. Besides--every time a hood of a 7-figure classic Ferrari is opened on any car-related TV show, there are Frams.
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
My problem has always been with the oil filters that have a rounded rubber gasket rather than the flat wide gasket for sealing against the block. You can't tighten these enough to make it stop leaking. A new crush washer on the drain plug costs virtually nothing, and saves on those driveway spots.
Other than the 996 and wife's G37 I have used Fram most of my life. No issues.
I have seen the burst cans from Fram.
I don't know if they still do, but they used to have a cardboard bypass that let the oil bypass the filter element.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Non Compos Mentis
No Fram for me- The insides are downright scary. The non-Porsches use Wix. Never had a problem with the threads. The Porsche gets Mahle filters purchased here at Pelican. |
(the shotguns)
Use purolator gold in the jeep. Very grippy.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
