Big Engine Damage
For the PPOT Brain Trust:
2008 Navastar (International) DT466 - 6 cylinder in line diesel. Was running just a little bit rough... Loss of power, no lights whatsoever on the dash (and there are MANY) were lit up.
So my question is, what do you think happened? My mechanic says the bent pushrod is from #4, and the bad lobe is #2. I can't make sense of that.
#2 Cam lobe
Another lobe starting to go:
What I think is a good lobe:
1972 911T/S MFI Survivor
Old 03-01-2016, 01:08 PM
resident samsquamch
sand_man's Avatar
Whoa! Lots of "bluing" (heat) on that camshaft.
-jeff
Old 03-01-2016, 01:13 PM
FLYGEEZER's Avatar
It looks like your engine s*** itself.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 03-01-2016, 01:17 PM
Banned
cam metal looks like it was full of airbubbles
when I got a core motor to rebuild for a 455ho gto
the cam had wiped out two lobes
but they were wore down WITHOUT PITS OR HOLES
i WOULD E-MAIL THOSE PIC'S TO THE CORPS REP
a bad casting with tooo much air intrained prior to machining is my guess
Old 03-01-2016, 02:10 PM
Thanks. The engine had 150K on it, and I was told the driver must have miss-shifted. After I saw the parts I started to wonder.
Old 03-01-2016, 02:13 PM
Dang. That cam is a disaster yo. How many miles are on it?
Old 03-01-2016, 02:14 PM
150,000 miles on the odometer, but the truck was purchased used. Actual mileage may be less.
Old 03-01-2016, 02:17 PM
Unregistered
sammyg2's Avatar
Old 03-01-2016, 02:19 PM
Typical Binder. Fix it sell it buy a truck with a Cummins
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
Old 03-01-2016, 02:24 PM
Binder?
Old 03-01-2016, 02:39 PM
In the rubber industry, we call all those tiny bubbles....porosity. Never seen it in a cam lobe, but obviously, the cam maker had a heat issue while molding the cam. Possibly not a long enough cure time, or excess gassing.
Old 03-01-2016, 02:48 PM
Now in 993 land ...
aigel's Avatar
I buy the over-rev. theory. Lobe wear is one thing, but lobe chunks and bent pushrod? Manual trans?
G
81 SC (sold)
Old 03-01-2016, 02:50 PM
pete3799's Avatar
Binder?
Corn binder some times referred to as a 13 letter s&!t spreader.
Like Dan said rebuild it and get rid of it.
Pete
79 911SC RoW
Old 03-01-2016, 02:58 PM
wdfifteen's Avatar
This grove worn into the cam is not from over reving. I'll go with bad cam. Improperly hardened.
Old 03-01-2016, 02:59 PM
Engine has been rebuilt. I am not up on California smog rules as I should be, but a Cummins swap would strike me as not at all possible.
Old 03-01-2016, 03:02 PM
rfuerst911sc's Avatar
One can of Engine Restore or Slick 50 you'll be good to go
Old 03-01-2016, 03:17 PM
pete3799's Avatar
Don't swap motors swap trucks. We just traded a 2011 International with a Maxxforce motor(most unreliable motor I've ever seen ) for a new Kenworth with a 485hp Paccar motor.
Pete
79 911SC RoW
Old 03-01-2016, 03:22 PM
Rebuilt with a ****ty cam I think. Was the oil pressure good?
Old 03-01-2016, 03:25 PM
resident samsquamch
sand_man's Avatar
I know nothing about this engine, but I wondered the same...oil starvation?
-jeff
Old 03-01-2016, 03:48 PM
Evil Genius
Rusty Heap's Avatar
Dr McCoy pointing to never seen before member of the Star Trek security landing party wearing the red uniform shirt:
"He's dead Jim"
Life is a big ocean to swim in.
Wag more, bark less.
Old 03-01-2016, 04:02 PM
