Did the fuel pressure regulators go through the plating bath?
1977 911S 1973 Alfa Romeo GT Veloce 1997 Lotus Turbo Esprit V8 2016 AMG C63S |
The ones in the pictures did but they were plugged. The ones that are on the engine are brand new.
Go Packers!
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
That is a pretty engine. Did it sell as yet?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thank you. Not yet. I still have not added up all the parts. Scared to.
I plan on making a list of all new parts and all of the parts that I have had to source used. Also, the machine work that was done.
We all would love to see what that beauty cost to replicate. I am not in the market, my engine only has 16,000 miles since a total rebuild.
I have put the rest of the heater ducting on and bolted on the muffler. The only things left to do at this point are to take it out of the engine stand, mount the new flywheel and clutch assembly (yes...NEW), make the calls to Jerry Woods for dynoing, and go from there.
OH! And add up all the receipts and make the list of parts new & used here. Ugh!!! NOT tonight.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
It's done...for the most part. I spoke with Jerry Woods yesterday about getting it broken in on the dyno. He said it may be a bit before he can get me in. The only things left to do are to remove it from the engine stand, install the flywheel seal, flywheel, ring gear, clutch assembly, and the last piece of sheet metal. Here she is.
![]() ![]() ![]() And the LIST! New parts list: Main bearings. std./std. Rod bearings. std. ARP rod bolts & nuts. Rod bushings. Countershaft bearings. std. Countershaft sprockets. Timing chains. Idler sprockets. Idler shafts. Cam sprockets. Chain rails. Upper and lower end gaskets sets. (Wrightwood Racing) Steel head studs. (Raceware) Oil return tubes. Oil pressure switch. (OEM) Oil pressure sender. (OEM) Barrels and pistons. (Mahle Nikasil) Intake valves. Exhaust valves. Valve guides. Valve stem seals. Valve springs. Cylinder head nuts and washers. Rocker shafts including inner hardware. Rockers. Swivel feet and jamb nuts. Cam tower oil galley plugs. Cam end cover plates. Cam feed lines and pipes. Air cleaner assembly. Speed and reference mark sensors. Oxygen sensor. CO% sample plug. Breather hoses. All new engine fuel lines. (OEM) Fuel pressure regulator. Fuel pressure dampner. Engine tin at speed and reference sensor area. Center intake boot and clamps. Rubber vacuum elboes and Y's. Sheet metal combo bolts. Intake manifold nuts and washers. (OEM) Intake manifold heat insulator blocks. Heater blower fan and rubber mounts. Exhaust studs and nuts. Injector seal kits. Alternator ground cable. Alternator air deflector. (in back of alternator) Spark plug wire set. Spark plugs, ditributor cap, & rotor. Alternator belt. Main engine oil pipe. Cushsion clamp and support bracket for pipe. Crimp clamps for brake booster venturi assembly. Stainless vacuum venturi pipe. (OEM)$$$ Support bracket for venturi assembly. Catalytic covertor heat sheild brackets, captive nuts, bolts, & washers. Muffler straps & bolts. (OEM) Muffler tip. (OEM) Heater pipe sleeves and hose clamps. Flywheel, pressure plate, clutch disc, throw out brg, flywheel, and clutch bolts. Pilot bearing. Misc. mounting hardware. Stickers for oil fill and air conditioning quantities. Machined or refinished items: Crankshaft. Magged, Polished, oil galley plugs r&r and cleaned, cross drilled for better oil delivery.(CCR) Connecting rods. Recondtioned with new rod bushings. (German Precision) Cylinder heads. Complete valve job. (MTE Inc.) 964 spec Camshafts. (Elgin Cams) Plating. (Swift Metal Refinishing) Fan, housing, strap, and pulley hardware. (Mark Motshagen) Powder coating. (West Coast Powder Coating) Used parts sourced: Heater boxes & cross over pipe. Stainless heater cross over pipe. Muffler, catalytic converter, cat. conv. heat sheild. Plastic heater "S" pipe. Brake booster venturi assembly. Speed and reference sensor mounting bracket. I am sure there are a few items that I have forgotten to include.
Did you get the memo?
That's purty, job well done!
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I bet that parts list was over a hundred bucks!
Beautiful engine. I am real glad I don't need it.
Damn that looks pretty
Thank you for the kudos on the build. I take a lot of pride in the motors I build. I do not enjoy the clean up and prep work of building engines. I am my own worst critic. It is a ton of work and elbow grease! If it isn't "Dan" clean, it is not clean enough! I do enjoy the build process and the hunt for missing parts. I also enjoy the time helping others to see what it takes to do the job right.
And now to answer the question that I am sure a lot of you have been waiting for...Price. The price is $30,000 outright. Price updated3/2/17
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE Last edited by syncroid; 03-03-2017 at 04:58 PM.. |
She's a beauty dan! best wishes on the sale!!!
Crickets after you posted the price..........that's a lot of coin for an engine without a car.
You do nice work. Can't wait to see it on Jerry's dyno.
12' GT3 18’ 991S Last edited by avi8torny; 10-15-2016 at 07:32 AM.. |
Yeeeeahh, that is a tiny bit over my budget to repower my Westfalia....
Good luck selling it! |
Well it looks like dyno time at Jerry's is out of the question. Minimum two month wait time. I am going to check out one other recommendation. Worse comes to worse, I will make arrangements with one of our customers to "borrow" their car for the break in.
Price dropped 3/2/2017
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE Last edited by syncroid; 03-03-2017 at 04:59 PM.. |
Grappler
A 3.6 would have appealed to a broader market. Most of the guys swapping motors on an early car (69 thru 83) are skipping the 3.2 and going straight to the 3.6 especially at that price point. This motor is almost basically stock which seems to conflict with the objectives sought by most hobbyists looking to put together a "big" motor/early car hotrod, so although beautifully executed and documented, I think the market for this engine at the current price point is very small. Having said that, it only takes one buyer. The engine looks fantastic, good luck with the sale.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
2manyprojects
Don't kid yourselves, this was a bargain.
When I first read his thread, I thought that's a lot of money for a stock 3.2.
After rebuilding my own 3.2 with 70k miles, and really trying to make it right, my perspective is- this motor was a freaking bargain for the level, of skill and detail that went into it. Yes, it could have been rebuilt cheaper- no plating, redo rockers, plate cylinders, etc, but this wasn't about that- this was a quality build, no corners cut. On another note to the poster- thanks for posting the links to your build pics. I received my engine partially disassembled, and your photos answered many questions. A true resource. Thanks! |
