wdfifteen's Avatar
Any Meat Smokers Here?
I've been making my own fresh sausage for years - bangers, chorizo, italian sausage, brats, farm sausage, etc. I don't use nitrites or nitrates so it goes right into the freezer. I've always been leery of chemical preservatives.
I stepped over to the dark side this year and made some cured Peameal Bacon. Had to use nitirite. So I've come this far and Mrs WD is pushing me to go all the way and get a smoker.
Any meat smokers here? What are your experiences? What equipment do you use.
Old 12-03-2016, 12:40 AM
WPOZZZ's Avatar
OT Gift Exchange?
Old 12-03-2016, 12:45 AM
UnRegistered User
billybek's Avatar
I have a big green egg and have used it on a variety of yummy dead animals and fish.
It really isn't big enough to do large quantities though and a real smoker or pellet smoker would be a nice thing to have. It is very versatile though and makes terrific steaks, burgers and fish.
Check out some of the smoker forums. I have found some great info through them.
Bill K.
Old 12-03-2016, 05:28 AM
I have a traditional style smoker and hardly ever use it. Tending the smoker for as long as it takes to smoke a pork shoulder is a royal pain in the ass. Even smoking ribs takes a half day. Never tried to smoke sausage that I made myself; it's too easy to smoke the store-bought stuff. Smoking salmon or trout would take much less work but a local market sells that and it's too easy to just buy it.
JR
Old 12-03-2016, 05:36 AM
Recreational Mechanic
Nickshu's Avatar
I have had a traditional (R2D2 shaped) charcoal smoker and an electric smoker. The charcoal worked great but was a pain to use b/c it required constant attention.
I bought an electric cabinet smoker but after using it a bit I realized the way it really works is more of an oven than a smoker. The smoke does not actually cook the meat, it just adds flavor. This makes it hard to render fat out but does work well on lean things like poultry or fish. If you want to do beef or pork prepare to be disappointed.
The next one I have my eye on is a Traeger barrel type pellet smoker. A buddy has one and I've had some impressive meat off of it.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-03-2016, 05:55 AM
My friends call me, Top
Skytrooper's Avatar
I use a propane fired smoker. It works great and no need to babysit it. I have been making my own sausages for 6-7 years now. This year I am planning to make some smoked bratwurst. I am waiting for the outside temp to get lower so that I will not have to worry about possible spoilage before or during the cold smoke process.
Matt
'87 924S
Old 12-03-2016, 06:09 AM
Smokers take some learnin'. The variables are manifold. In the last 6 months, I have learned to smoke/cook babyback ribs that I am proud to serve......there were some disasters on the path.
Taint a walk the pork.
JPIII
Early Boxster
Old 12-03-2016, 06:35 AM
I have a BGE and use it for brisket, pork shoulder and ribs. Also, cooked our Thanksgiving turkey which came out very juicy with a light smokey flavor. I follow Aaron Franklin from Austin. He promotes Central Texas style BBQ. Look for his YouTube videos. Once you learn to manage the temps on the Egg through manipulating the vents, then buy an electronic temp controller. Now I can smoke pork shoulders overnight or while I'm at work. I use the IQ 110 controller which cost about $150.
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 12-03-2016, 07:38 AM
craigster59's Avatar
Here you go. Why half step when you can go full bore?.... http://www.goodshomedesign.com/how-to-build-a-smokehouse/
Old 12-03-2016, 07:47 AM
A Man of Wealth and Taste
tabs's Avatar
David Klose smokers Houston. He bilt the Johnsonville Brat Tanker smoker. The guy knows a thing or two about building BBQ's.
Old 12-03-2016, 08:56 AM
tabs's Avatar
You are looking for a Vertical unit where u can hang sausage etc in wt a firebox on the side for indirect heat.
I have been through all of this before about how 1/4 and 1/2 inch steel plate retains a constant heat where you do not have to dick around trying to maintain heat.
Old 12-03-2016, 08:59 AM
cycling has-been
bkreigsr's Avatar
Let me know if you suffer any unexpected symptoms - wasn't nitrate and it's derivatives once know as 'salt peter' and routinely added to prison food?
Bill K
Old 12-03-2016, 09:03 AM
TheMentat's Avatar
I've used a Weber Smokey Mountain (aka Weber Bullet) for years. Its gives great results, holds a lot of meat, and is not terribly expensive. It takes a while to get good at it, but there's lots of online resources. Alternatively, there are a lot of electronic peripheral devices that will basically guarantee a consistent result.
I've also had great results with the Big Green Egg (which is more versatile, as it will cook at high temperatures). However, if I were to upgrade, I'd get one of these:
Yoder Smokers | Pellet Grills
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 12-03-2016, 09:34 AM
The Stick
RKDinOKC's Avatar
I recently got a Charbroil Truinfrared Smoker, Roaster, Grill. It is basically a propane oven with a small smoker box to ad flavor that also has a grill on top. Temps range from 650°F to 300°F. Am very surprised at how well it does. Especially since it takes a LOT less time to cook even at 300°F. Found one for $125 so figured it was worth a try.
Did my 20lb Thanksgiving turkey using a leave-in bluetooth thermometer and it was cooked in just 1 hours. Wrapped it in foil and a towel and let it set in a cold oven for 30 minutes to finish out. It was wonderful. Had both it and a roast in bag oven cooked turkey at our family dinner and there wasn't any smoked turkey left. It was ever bit as tender and juicier than the oven bagged turkey and also had a smooth smokey flavor (used Applewood) that everyone loved.
Have also smoked a pork butt that turned out really tender, juicy, and delicious. I don't understand how, but it comes out much different than cooking in an oven. They claim it is because it uses infrared heat instead of air to cook so doesn't have the tendency to dry the meat out. As with the turkey once it gets up to temp you remove it from the smoker, wrap in foil and let finish cooking (slowly cool) for 30 minutes.
I also really enjoy leaving it cranked on high, putting a couple charcoal briquettes in the smoker box and grilling. Then every thing cooked on the grill top is just like it was cooked on a charcoal grill without having to mess with lighting and managing the charcoal. Have really gotten into mixing different chips and charcoal for different smoked flavors. Just load up the smoker box, light it, and by the time I've got the meat ready to slap on the grill or drop in the smoker it is hot and smokin.
Instructions say you can not put chips in the smoker box and it cooks stuff like a fryer. The recipe says you just rub the bird down with peanut oil before cooking. But haven't tried it yet. So far I'm enamored with smoking. Have tried doing some burgers with out the smoker chips and even without the smoked flavor they were more flavorful and juicy than my gas grill ever did.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 12-03-2016, 09:41 AM
wdfifteen's Avatar
Bill K
No, saltpeter is potassium nitrite. Curing nitrite is sodium nitrite. It's a necessary ingredient for cured meats.
https://www.spicejungle.com/curing-salt?gclid=CjwKEAiA94nCBRDxismumrL83icSJAAeeETQTGp 7MF3wbhpKLHey70KyVnX1Ux07hf4vy4wyUHq3URoCdi3w_wcB
Old 12-03-2016, 10:11 AM
wdfifteen's Avatar
Yep that's what I'm thinking about. I don't want to cook the meat, just flavor and preserve it. Temps are around 140 degrees as I recall.
Sounds good.
Old 12-03-2016, 10:12 AM
atcjorg's Avatar
look up traeger...smoking for dummies , can't get any easier
81 sc 3.0 turbo wb coupe
Old 12-03-2016, 10:49 AM
Charles Freeborn's Avatar
I can do everything from very slow smoking (150ishº) to 700º pizza cooking in my Big Green Egg.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 12-03-2016, 01:19 PM
I've got a BGE clone ("Black Olive") and it does very well for smoking and grilling. I bought one of these for the versatility (couldn't justify both a smoker and a grill to the wife, though I tried hard).
I've seen some of the Yoder smokers at a shop here locally - they are certainly very well built.
Old 12-03-2016, 03:45 PM
Feelin' Solexy
Tishabet's Avatar
That's what I have. Large enough for 4 full racks, real smoke vs electric or propane, and I can set it off then leave for a full day of work and come home to dinner. Best of both worlds, I've had mine for two years and probably use it twice a month.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 12-03-2016, 04:05 PM
