A930Rocket's Avatar
200 amp breaker panel replacement
I'm on my phone and can't do a good search.
My parents house in Atlanta needs a new 200 amp breaker panel according to an electrician they had over. He was there to fix some GFI's and look at why some rooms outlets or lights were sporadic.
He said a breaker was swapped out at some time years ago and has melted some of the aluminum in there. No pictures. Said it was a hazard.
Said it would $2,200 to replace. Seems expensive but what do I know.
What's the going rate to replace a 200 amp box?
Old 07-10-2017, 09:56 AM
Detached Member
Hugh R's Avatar
I had the same thing happen 30 years ago, and the first electrician wanted like $2000, my wife called the trusted electrican from the school district she worked for, he pulled the breakers and wire brushed the aluminum buss bars and charged us $200.
Shop around, if 1/2 the house has electricity and the other 1/2 doesn't, its a dirty buss bar.
Interesting, I'm going through the same thing with a bad breaker, that is obsolete today.
Hugh
Old 07-10-2017, 10:07 AM
I had a 100 amp panel switched out for a 200 amp panel over a year ago & the cost was $2K. That was using a commercial electrical company.
Marv Evans
'69 911E
Old 07-10-2017, 10:14 AM
entertaining the idea
UconnTim97's Avatar
I had the same done by a local guy this winter. It was a little more than $2K, but they also installed new outlets outside and a new ground wire to bring everything up to code, etc.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-10-2017, 10:32 AM
Yep, about 2k plus a few bucks out here
Old 07-10-2017, 10:38 AM
It depends if it is a 200 or a 221 panel. Whatever it takes.
Old 07-10-2017, 11:54 AM
MBAtarga's Avatar
$150 for the panel with some breakers, add several hundred more for some AFCI and other breakers - around $5-600 for parts only.
Mark
'83 SC Targa - since 5/5/2001
Old 07-10-2017, 12:38 PM
Puny Bird
Mark Henry's Avatar
The aluminum wiring is adding cost, here code is CO/ALR parts must be used.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 07-10-2017, 01:07 PM
He may not have aluminum wiring, it sounds like the panel used and aluminum buss bar...
But if you do have aluminum wiring be careful with your next panel, it needs to be compatible.
Old 07-10-2017, 01:15 PM
Platinum Member
dad911's Avatar
Is it 200amp now, or are they upgrading service also?
A930Rocket's Avatar
It's a 200 amp service now.
House was built in 1976. It has copper wires in it. At least at the outlets I've seen.
Guy charged them $200 each for new GFI's.
Old 07-10-2017, 06:03 PM
Band.
A GFI breaker for my panel is $40, a dual-function GFI/AFCI almost $50. $200 seems a little ambitious even with a little markup.
1983 SC Coupe
2020 Macan Turbo
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 07-10-2017, 07:13 PM
John Rogers's Avatar
Before you worry about the lowest price, if it were me I would ask the following questions:
- Does the replacement require a permit from the city/county?
- Does the electrician have to be licensed?
- Is the electrician bonded or insured and is the work guaranteed IN WRITING?
When we had solar installed, the original breaker box was installed when the house was built in 1961. Cost to do it with parts and labor was $3000. It was guaranteed by the solar company AND the electrical contractor. Everyone who worked on things was licensed but we live in CA so.....
Old 07-10-2017, 08:03 PM
A930Rocket's Avatar
Good questions and my thoughts as well.
Old 07-10-2017, 08:08 PM
GWN7's Avatar
A guy I worked with has a electrical business. Seven years ago I asked him to upgrade my panel from 100 amp fuses to a 200 amp breaker panel. He quoted me $1500 and then never came to do the work. Either he has a crappy memory or he quoted me too little.
Bunch of old cars
Old 07-10-2017, 08:16 PM
Locally the first two items John mentioned are requirements. The third should be a requirement by you if not by the city/county.
Marv Evans
'69 911E
Old 07-10-2017, 09:14 PM
canna change law physics
red-beard's Avatar
My parents were looking to move their breaker panel from outside the garage to the same spot but inside. The issue was the breakers used were oddball and code has changed. It was going to be $3K to get it moved. Seems stupid to put a breaker panel on the outside of the house in Houston.
James
Red-beard for President, 2020
Old 07-11-2017, 04:31 AM
