We never use their clips. Here's how we install our sinks. The sink (rim part) actually sits on the sub top (cut out sub top using sink's template that comes with the box). this way the sink will never fall out if clips should rust or break (they rust all the time) When sink's filled, that's a lot of weight with just a few epoxy plugs and a screws, glue or no glue. This works for stainless sinks. For cast iron, we have a double sub top just for the sink. We built our cabinets with a solid top, then cut template out to fit sink. Cut sub top around the sink so it sits flush with the rim. Granite or quartz fits perfectly flush on top of that. I would not do it any other way because if that sinks should fall, someone will lawyer up. There's no way this or any sink will rip through 3/4" plywood even if you or my fat ass jump on the sink. Our lil' bathroom sinks are installed that way too. Last edited by look 171; 09-09-2017 at 09:32 PM.. |
If granite, request to groove and epoxy a steel rod like a rebar across the front of sink area. It helps stiffen it up to prevent cracking. My fabricator do this on all our installs.
Miter the edging is also standard. I know some shop require a special request for this. |
Our sink was done the way look describes and it feels rock solid.
We also got a thick gauge stainless sink with sound deadening material on the outside. Doesn't have that tinny sound like old school stainless sinks did. |
One thing that has been used in bathrooms and now finding it's way into kitchens is glass counter tops. I have not seen them in a kitchen in person, but here is a link I found at random. Glass Tops for Cool and Unusual Kitchen Designs from ThinkGlass - DigsDigs ![]() ![]() Quote:
Cast Glass Counter Tops Tables - Glass Art Studio 2, Boston MA ![]() Quote:
The thing that disturbs me about most counter surfaces is that they are so cold to the touch. Outside of wood like butcher block which isn't' very sanitary there just are no options. The other factor is glare or sheen, a positive or negative depending on your natural and artificial lighting. Here is another favorite of mine - soapstone, used to be affordable domestic quarried. Now told it is imported and expensive, the US quarries ran out and the South American stuff is way fancier, glass veining in it and exciting looking. https://www.countertopguides.com/guides/the-pros-and-cons-of-soapstone-countertops.html Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 09-10-2017 at 02:27 AM.. |
We've had granite for 5 years and don't find sealing now and then to be a hassle. I like it in general, but we already have a few 1/4 inch and one 1/2 inch chip in the edge around the wash sink. It's pretty muc inevitable that heave pans are going to contact it. I'm looking for some kind of rubber pad to cover that edge with.
All I know for sure is don't use copper.
Local microbrew pub has copper bar tops to match brewing equipment. If you wear a white shirt and lean your forearms on the edge it will stain the shirt black. They are constantly cleaning it, but it oxidizes so quickly.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Did some web surfing this morning and found another installer/warehouse granite facility that has the same color granite installed for $9.00 less per S.F. so will go visit them today . So $45.00 a s.f. installed vs. $36.00 I wonder why such a large discrepancy ? Saving money is a good thing but want a quality install also . Online reviews for SEVERAL local companies are all over the map !
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Driver
For quartz, is the material strong enough that that extra step is not necessary?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Platinum Member
Soapstone - needs to be regularly oiled to look good, very soft, but can use woodworking tools to fabricate.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Platinum Member
Platinum Member
I've seen copper tps on bars (used std roofing rolls I think) then covered with clear epoxy.
Anyone know how much it costs to have a stainless counter with integrated sinks fabricated?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Went to the second vendor I found online they had great selection , seemed to know what they are doing and are $800.00 less expensive than the first vendor . Exact same material/color/style . While walking their yard the wife spotted another color/style that she thinks she likes better its called black pearl . Looks very close to the steel gray but with a hint of brown/gold/reddish . We'll check one more supplier then we will pull the trigger .
If your plan is to use SS, make sure its the correct type in terms of texture. Your idea of polish or stain is different then theirs. I used a restaurant SS fabricator. |
I know you are working on your kitchen. Talk with your contractor about the stone fabricator. ASk to visit the shop and see for yourself. If you are concern, I will help you out and you can hire my fabricator. Just let me know because I have to make arrangements for you because they do not deal with the public. Those guys have two water jet machines (about 150k each) along with a bunch of other computer control machinery just for working on granite tops in a 40,000 sq' building. They are not your hand cutting and polishing guys. Pricing is extremely competitive. They did Jim's kitchen. I think you have seen it. Last edited by look 171; 09-11-2017 at 12:21 AM.. |
Now in 993 land ...
My kitchen is about 20 years old, courtesy of the previous owners.
It is white and has light green / grey corian counter tops. They look new. You would not think they are that old. You may have seen them in some of my technical images with car parts on them! The material tolerates scratches, cuts with a knife etc. almost self-healing. Zero maintenance / sealing etc. What is really great - and your wife will appreciate it - is the fact that the sink (double sink) is also corian and molded into the countertop and so is the backsplash which is about 6 inches high. You can really wash and splash around and clean very well around the sink. If I had to build a new kitchen, I would totally go synthetic for the fact that you can have a single piece counter. Maybe some of the composite glass / recycled materials have this option as well. Cheers, G |
My g/f paid a few hundred to have hers replaced...it cracked. Replacement was top drawer...have to look closely to see the fix.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
(the shotguns)
have corian and it's just not very exciting.
I'd look hard at DIY concrete. a very cool industrial look.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Timely thread!
We have granite. Love the low maintenacne and durability. Don't care for the color. We are contemplating a complete kitched redo, and quartz is on the top of our list... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
If there is any possibility that you will move/sell in the future then stay with a more neutral color/pattern. It's really fun to walk the slab yard and find some really unusual pieces. I was tempted to go with a really bold slab for our island that had colors to match the rest of the kitchen but thankfully didn't go that route. Stay with mostly earth tone slabs with hints of color you like.
We toured a home that was slightly above our pay grade - but could have made a couple changes and pulled it off. The killer was that the PO installed granite in the huge kitchen and all bathrooms that was mostly varying shades of green with a touch of blacks and gray. Tile floors and walls in the bathrooms followed the trend. I would have had to demo and replace all of it...no thanks. The worst I have seen was a black and salmon colored granite kitchen. Barf. I really like the SS top (rick-l) as a smaller accent - like for a coffee/wine prep area. Even though SS is wildly popular for appliances and sinks be careful going for full kitchen counters. I know some folks who think those belong in morgues and would never OK a kitchen install. Last edited by JavaBrewer; 09-11-2017 at 01:46 PM.. |
