Recreational Mechanic
Nickshu's Avatar
Originally Posted by JackDidley View Post
Way better than $577. They also list a Graf with a brass impeller. Not making the call until I do some more reading. May search some threads on Rennlist. Not registered there but their forums do get some traffic.. Probably do the belt and stat while I am at it. When I make the call I will buy it all from pelican. Great service here in the past.
Not sure if it's popular on Caymans but on 996/997's the low temperature thermostat sold by LN Engineering is a popular thing to install.
Sent from my Samsung Tablet using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-25-2017, 09:34 PM
Yes, leaning toward the 160* stat as well.
Old 12-25-2017, 09:49 PM
Almost Banned Once
sc_rufctr's Avatar
I've never seen a metal impeller fail. What fails is the seal or the bearings.
- Peter
Old 12-25-2017, 10:10 PM
Arizona_928's Avatar
common failure on the VW TDI's when replaced with a plastic impeller. OE is metal.
Plastic ones fail when the glue between the impeller and shaft fail and the shaft freewheels...
However those are on iron block engines... I like the argument since it's an aluminum block; it needs a plastic impeller.
dolor et pavor
Copyright
Old 12-25-2017, 10:19 PM
Did you get the memo?
onewhippedpuppy's Avatar
Seems like I saw an account on Rennlist of spmeone’s metal impeller pump taking out some of the block. Considering that it’s common to have the bearings start getting loose and leaking, I wouldn’t want to take the chance with a metal impeller. Go brass or plastic.
‘07 Mazda RX8
Old 12-26-2017, 06:05 AM
Ive done a lot of searching on water cooled forums and found a lot of warnings about the metal impellers. That is all. Warnings but no one actually saw one destroy a motor. So far.
Heading out to get some hose crimpers and E torx sockets. Later today I will order some parts. Not sure what parts but I will order something.
Old 12-26-2017, 07:27 AM
DanielDudley's Avatar
It happens. Go over to Rennlist and check it out on the 928 forum. I think someone actually made a block repair kit for those engines. Usually you are going to run out of water before you kill the face of the block, but not always.
Old 12-26-2017, 01:47 PM
I think you are correct. A bad bearing will let the impeller wobble and hit the block but the seal should give up before the block is hurt. I wanted to get a look at the old pump today but decided to wait until I have parts. If it is together I can at least move it in and out of the garage if needed.
Old 12-26-2017, 02:40 PM
Functionista
manbridge 74's Avatar
Originally Posted by BSiple View Post
I haven’t replaced mine, but I will be going with the factory type when I do. They are better engineers than I am...
The Porsche pump is good for maybe 35K miles. Some last longer. Tony Callas (Rennsport) and some p-techs recommend 35K as a preventive measure for replacement. Why? It is a small pump in a tight spot designed to pump just enough with out too much power robbing parasitic draw. (Racecar origin)
I would think the metal impellers might cause more seal wear due to same size seal but more weighty impeller. YMMV.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-26-2017, 07:26 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
LOTS of threads on RL about this... The OEM plastic impellers get eaten away over time and dislodge and block vital coolant passageways and boom goes your engine. If the bearing fails on the metal type, it will score the block making it useless... Tough choice... If you go plastic, go with the 997 OEM part. Has a more robust plastic impeller.
Marc
Old 12-26-2017, 08:44 PM
Ordered pump with a brass impeller. 160* thermostat, an OE belt and gaskets. Just can not see a $250 pump. When I post up 2 years from now about my trashed motor you guys are welcome to beat me down. I promise not to blame Pelican for selling me a crappy pump.
Old 12-26-2017, 08:55 PM
Functionista
I’ve done probably 50 of these and haven’t seen one “eaten away.” They break when the impeller contacts block. Usually after a guy has been limping one along, adding coolant every so often instead of getting around to replacing it.
The new updated part is a 997 part number, I don’t think you can get old 996 part though some places may still have inventory.
Jeff
74 911, #3
Old 12-26-2017, 09:09 PM
Functionista
No way I’d replace factory t-stat with some other brand....
Jeff
74 911, #3
Old 12-26-2017, 09:10 PM
Of the 50 you have done, did any have damage to the block ?
Old 12-26-2017, 09:57 PM
I'm putting this under water cooled, seems fitting
-15 C here today with a wind chill factor of -30C (Here they call it "Windshield factor)".
I've worked at this wharf for more than 45 yrs and this is the coldest I've ever been.
Old 12-27-2017, 11:13 AM
rattlsnak's Avatar
Probably half of the ones we've done at the shop have had some pieces missing/broken off of the plastic impeller type.
Marc
Old 12-27-2017, 11:18 AM
Yellowperil, That looks seriously cold. It was 7* F here this morning.
Old 12-27-2017, 01:39 PM
Functionista
Just light scuffing. And yes, a few with pieces missing but not eaten away like dissolving or anything. I have a way to get pieces out but usually not needed, though I make sure to let customer know that it could be an issue. They usually look pretty good, just leaking.
Jeff
74 911, #3
Old 12-28-2017, 09:17 AM
Thanks. I am dieing to see whats is under my pump and if it is original with 81000 miles on it. The belt is OE but it looks too new to be factory. I bought a new OE belt to put on. I also bought the 160* thermostat but I am not sure I will use it. Its 18*F here and parts should be here Saturday, so no point in heating the garage before then.
Old 12-28-2017, 09:31 AM
Gon fix it with me hammer
svandamme's Avatar
I just installed a Pierburg replacement, supposed to be the OEM
Came with composite impeller.
looks just like the pump that came out.
(which as it turns out was leaking on the gasket, the bearing and impeller was still just fine)
Installed the cooler 72C thermostat as well
Pierburg on top A+
That's what I'de get if it's available. Payed 177€ for mine.
A skf, geba, laso supposed to be good as well
B then it's meyle, metzger, febi etc
C the obivous no name chicom made crapola
Or obviously you can order Porsche original teile
Just make sure to order some lube up front
Stijn Vandamme
BIMDIESELBMW116D2019
Old 12-29-2017, 02:02 AM
