A930Rocket's Avatar
Is there a quiet air compressor?
We’ve got a dry sprinkler system in our clubhouse. It has a small Husky air compressor to refill the air as needed. It sounds like a jet engine when it runs and can be heard throughout the bldg.
We are trying rubber feet, another muffler and maybe an insulated box to quieten it down.
If that doesn’t work, well look at other compressors, but we want a quiet one. Are there any out there?
Any suggestions?
Old 01-16-2018, 06:17 AM
rfuerst911sc's Avatar
To my knowledge there are no " quiet " compressors but there are quieter . You don't mention if the current compressor is an oil less or oil type . Generally the oil less are noisier . My best suggestion is small oil type compressor and then get creative on noise suppression in the area that the compressor is mounted . Build a room within a room ? Heavy insulation , double thickness sheetrock ? But keep in mind you would probably need a source for incoming air to cool the unit when it is running .
Old 01-16-2018, 06:26 AM
The only way to make a quiet compressor would make it really slow.
At one of my former offices we had air ported to lots of places in the building. The compressor was in a back room up in the ceiling, hanging from four rods on spring mounts. The ceiling tile panel made it pretty quiet. We put in a high quality oil field grade stainless steel ball valve in the bottom of the tank. Just kill the compressor and and turn the handle and drain the tank. It worked great for 25 years. Changing the oil on the compressor was a pain, but not horrible. If you were in that room you could hear it but having a conversation was not a problem.
It was an expensive and complex solution, but it worked great. The easy choice is put the compressor outside.
Banned
I think you can get a screw drive compressor that is a lot quieter.
Old 01-16-2018, 06:37 AM
A930Rocket's Avatar
It’s an oil less system located in our riser room, which is in the middle of the building. At this point, there is no way to move it, double the drywall or insulate it.
The sprinkler trade says it should not come on very often. Only if there is an air leak. When it does come on though, it’s very loud. There is a check valve in the system as well.
Old 01-16-2018, 06:58 AM
Unregistered
sammyg2's Avatar
Put a silencer on the suction side.
Old 01-16-2018, 07:02 AM
(the shotguns)
berettafan's Avatar
have you experimented with acoustic foam and the like?
would be interesting to put a spectrum analyzer in the room and search for materials that absorb the prominent frequencies.
Old 01-16-2018, 07:03 AM
beancounter
jwasbury's Avatar
Eastwood is now selling a scroll type compressor that is extremely quiet. Its not cheap but I think its the least expensive scroll type compressor on the market. They sold out of the initial run and are taking orders now for April delivery.
Old 01-16-2018, 07:06 AM
https://www.eastwood.com/scroll-compressors
Due to overwhelming demand, we have sold through our limited pre-sale quantities of Scroll Compressors.........................
How a scroll works.
A scroll compressor has only one moving part -the rotating scroll.
The rotating scroll is moved in an elliptical pattern by the electric motor output shaft inside of a corresponding stationary scroll . The elliptical movement pulls air in from the outer edges and efficiently compressor the air charge toward the center of the scroll . This constant displacement pump design reaches 100% volumetric efficiency and ultra-quiet operation with minimal components.
LOOKS LIKE THEY STILL HAVE IT'S BIGGER BROTHER.
https://www.eastwood.com/eastwood-qst-30-60-quiet-scroll-air-compressor.html
Eastwood QST-30/60 Quiet Scroll Air Compressor
Item #31700 Scroll Compressor
★★★★★ No rating value ★★★★★
Industrial Technology that is Powerful, Quiet and Efficient
$1299.99
Innovative - Direct Drive Cast Iron Scroll Pump
Integrated Air Cooler - Multi-stage oil filtration system
Low Noise Level - Only 69db, 87% noise reduction over standard piston compressors
Compact Size - Performance of a 60 gallon in the size of a 30 gallon
Powerful - 12 cfm @ 40 psi: True output cfm 12 cfm @ 90 psi: True output cfm 145 psi max pressure, 100% Duty Cycle
Dependability - 100,000 hour pump life, 3.3 HP continuos duty motor, All steel pressure hard lines and hydraulic style flex lines
Old 01-16-2018, 07:12 AM
(the shotguns)
berettafan's Avatar
Ho
Lee
Sheet.
That has got to be the greatest innovation in amateur wrenching since the ratcheting wrench.
Old 01-16-2018, 07:17 AM
A930Rocket's Avatar
A quick search shows a lot of quiet compressors. We only need a 6-10 gallon unit. I saw that some were 45 to 60 dB’s. Cheap too...$350 and less.
Old 01-16-2018, 07:28 AM
Originally Posted by berettafan View Post
Ho
Lee
Sheet.
+1
And if it's $1300 at Eastwood, the exact same unit is probably available somewhere else for $400.
Old 01-16-2018, 08:06 AM
Danimal16's Avatar
Any suggestions?
Have you looked at California Air Tools? California Air Tools
I have this one (which is much smaller than you require):
https://www.amazon.com/gp/product/B00TDNKBMC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
It is a great little QUIET unit.
Dan
Old 01-16-2018, 08:27 AM
We run a couple of small Thomas compressors on our job. I love them as they are so much quieter then the home depot jobs but they are about 50% more money but worth it too my poor ears.
Old 01-16-2018, 09:45 AM
I have one of these... Shockingly quiet. Great compressor.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 01-16-2018, 09:52 AM
Recreational Mechanic
Nickshu's Avatar
That Eastwood unit looks good but too bad it's only 12cfms. Can't do much with that if you are a home mechanic using air tools or a blast cabinet.
Sent from my Galaxy S7 using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-16-2018, 10:46 AM
GWN7's Avatar
Acoustical drywall
https://www.acousticalsurfaces.com/soundbreak/soundbreak.htm
Just saw this on a DIY program. Absorbs 8X more sound than normal drywall.
Any chance to replace the existing drywall?
Bunch of old cars
Old 01-16-2018, 11:52 AM
VincentVega's Avatar
Simpler to line the walls with sound absorbing material, something like roxul works great. I have similar drywall on the wall shared with my garage. Works, and an improvement but there is more to it than just drywall.
Old 01-16-2018, 12:11 PM
Here's my question about the Eastwood scroll compressor: if the pump is really so badass, why give it a tank only 1/2 the size of a normal compressor? They cite 2:50 to fill the tank, but as a metric, it's interesting but useless - how often do you really fill the tank from empty?
Old 01-16-2018, 12:20 PM
With a 100% duty cycle I would expect it to be running all the time, at least with any high use tool.
Old 01-16-2018, 12:34 PM
