Jameel's Avatar
Help me wire up an old Ungo box to AC 120V
I recently pulled an Ungo box from a 911 and would like to hook it up in my garage as a functioning novelty. Kids (and me!) would get a kick out of pushing the red button and having the alarm blast. Also a great opportunity for practical joking with friends over.
So I've got the Ungo box here which I'm planning to simply gut of all the electronics, but keep the switch behind the red button for actuation.
I don't know much about electronics, but I can solder and figure things out. Looking for some assistance on what I need to do this (inverter, transformers?) so I can wire it up and plug it into a wall outlet.
I'm also open to just using a compact 12V battery. It's not like its going to get much use. Just a short burst from time to time. I can imagine a battery would last a while.
Thanks!
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 03-17-2018, 07:23 AM
What the hell's an Ungo box?
nevermind, google to the rescue
Old 03-17-2018, 07:46 AM
Any 12V wall wart transformer will work. They make them with bare leads that you can solder to the Ungo power leads. Or take any random one, cut the round plug off and strip the leads back.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 03-17-2018, 08:10 AM
Jameel's Avatar
I tried the 12V wall wart. Hz must be wrong. The horn sounded, but it was like it was sped up. Sort of like Alvin and the chipmunks version.
3.0 rebuilt by me
Old 03-17-2018, 10:43 AM
Platinum Member
dad911's Avatar
Needs DC, and proper polarity. Some wall warts are ac.
do you have a 12v jumper pack?
Politics is in the eye of the beholder - Rodney Dangerfield
Old 03-17-2018, 11:31 AM
Jameel's Avatar
I do. But not sure what that gets me.
Old 03-17-2018, 12:24 PM
Platinum Member
dad911's Avatar
Use the jumper pack as 12v supply/12v battery.
Old 03-17-2018, 12:51 PM
least common denominator
scottmandue's Avatar
Look at the wall wort, it should say AC or DC, as said you need DC.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-17-2018, 01:27 PM
T77911S's Avatar
you need a 12v power supply. you need to check the current rating on the UNGO and then get a PS with AT LEAST that current rating,
you probably used a PS too small for the device.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-19-2018, 03:49 AM
T77911S's Avatar
i see it only uses a 3A fuse so its probably less than 1.5A.. just s guess though
RACE CAR:: sold
Old 03-19-2018, 04:00 AM
