Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Replacing Coolant with AirLift System?
Hi All -- I recently purchased a low-temp thermostat and want to replace the coolant in my 987S, as it hasn't been changed since the water pump was replaced by a previous owner in 2013 or thereabouts. The AirLift vacuum system came highly recommended by others in the Porsche community, so I bought one to make the process go more smoothly.
Well, I have my AirLift system, I have my air compressor, I have my thermostat and coolant... but I have trepidation about actually doing the job, as I've never used a system like this before. Moreover, the instructions included with the system are fairly vague.
I'm sure it isn't a tough job, and once I get into it I'll figure it out... I did once do a top-end rebuild on a 951 engine (and replaced its transmission) in my home garage... but as with any new procedure, I'm cautiously hesitant. Have any of you used this method before? Could you offer me any tips regarding doing the job on a water-cooled flat-six Porsche?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 04-15-2018, 07:21 AM
syncroid's Avatar
The Air Lift is an awesome tool! You will need to access the expansion tank in the engine compartment to fill your system properly. The earlier 986 cars were a little easier with the expansion tank in the trunk. Just attach the Air Lift to the tank, plug in your air hose, and bring the system down to 25-30 inches of vacuum, close the valves. Let it sit for a few minutes to make sure you don't have any leaks, then open the fill valve from your coolant bucket. (I use a 5 gallon bucket) It fills the system very efficiently.
Good luck.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 04-15-2018, 08:08 AM
Writer/Teacher
CJFusco's Avatar
Good luck.
Thank you for the response. So, how do you know it's reached "25-30 inches of vacuum"? Is that what's denoted on the gauge? If so, when you start the procedure, what reading will it start with before going to 25-30 inches of vacuum?
Old 04-15-2018, 10:47 AM
syncroid's Avatar
Yes, by the gauge reading. Your Air Lift may be a bit different then mine. I remember doing some modification to mine. I'll have to take a look at it tomorrow when I get to work. Maybe I'll post a pic of it. I might even be able to come up with a photo in our database with the tool hooked up to a car.
Dan
Old 04-15-2018, 12:59 PM
syncroid's Avatar
http://i.ebayimg.com/images/i/251653184270-0-1/s-l1000.jpg
This is the kit I have. The modification I made was to drill and tap 180 degrees from the on/off valve and screw in the Filler valve to the new hole. That way, once the system was in a state of vacuum, you simply close the one valve, and then open the other valve to fill. Saves time!
Dan
Old 04-15-2018, 01:09 PM
ninelevenick's Avatar
I agree with Dan. The Air Lift kit is awesome! I just used mine for the first time yesterday on my 996. After replacing the water pump, thermostat, and draining all the coolant, filling the system with new coolant using the Air Lift was by far the easiest part of the job. As previously mentioned, once the 25 psi or a bit more is indicated on the gauge, close the valve, detach the hose, and monitor the gauge to see if the system holds pressure. If it does, attach the hose that has a filter on one end, and place that filtered end in the container of pre-mixed coolant. Attach your air pressurized air line to the other end, open both valves, and see your coolant get sucked into the system at a very fast rate.
Old 04-15-2018, 02:13 PM
Writer/Teacher
CJFusco's Avatar
Yes, that's the system I have as well. Thanks!
Old 04-15-2018, 03:46 PM
I have the cheaper version that is made largly of plastic but still high quality. It isnt very difficult to use, I think the other guys have it covered. One thing to remember is to have all the coolant you need in a single container so that you dont introduce air when switching from one to another
18 Cayman GTS
Old 04-16-2018, 06:31 AM
Stupid question, but why not pour it in from the top like it's been done for 100 years?
Old 04-16-2018, 07:07 AM
one of gods prototypes
bell's Avatar
Because of the heater core and radiator pipes that have high spots, if you don't vacuum fill it you'll get many air pockets.
I use mine daily at the shop....
Dont forget to flip up the vent spring when you fill it
Brought to you by Carl's Jr.
Old 04-16-2018, 08:54 AM
Yeah, but I have never had a problem with bleeding all of the air out...
I get the difference in using one in a shop, if you use it all the time and it saves a few minutes on each job. This is different...
Old 04-16-2018, 09:02 AM
fastfredracing's Avatar
The water cooled p cars are pretty tricky to bleed correctly the old fashioned way . The air lift is not just a time saver, it is a huge time saver
No left turn un stoned
Old 04-16-2018, 09:52 AM
syncroid's Avatar
Here is my set up.
Dan
Old 04-16-2018, 10:25 AM
Did you get the memo?
onewhippedpuppy's Avatar
I love my Air Lift, it's one of my favorite tools.
JR, if you've ever fought to bleed air out of a stubborn cooling system you'd understand the value. When I had a dealership I had a 2008 Wrangler that had a sloshing sound in the heater core because of trapped air, which was a common issue. I tried every trick to flush it out, nothing worked. 10 minutes with the Air Lift and the problem was gone.
‘07 Mazda RX8
Old 04-16-2018, 11:54 AM
Never had a problem with it. Wrenched on 60 or 70 cars and bikes and never needed one. Neither of the two shops I ran had a need for one. Guess I was just lucky..
Old 04-16-2018, 01:33 PM
Gon fix it with me hammer
svandamme's Avatar
you don't need any system to bleed a Cayman, it has a built in system.
fill it, run it, pull the metal tab on top of the coolant tank on the top right of your engine.
you will hear the air escape
fill it up, run it some more , repeat
do not drive untill your car's heater produces heat.
You might get some filling done after the first run
but once the engine is warm and reasonably filled up with coolant, don't try to fill it, the hot coolant will just spill through the overflow hole, over your engine.
it's designed to push out in that direction vs spill inside your trunk, you'll notice pretty quick when you hear it surging on opening the coolant filler cap.
So for the last bit of bleeding and refilling you'll have to let it cool down.
But the car is already driveable at that stage, if the heater works, and you pulled the little tab on a hot engine, most if the air will be out.
If it surges at that point, it's already full enough to drive.
It's half an hour work,
15 minutes stationary, 5 minutes to bleed & refill, 10 minute drive
Then an afternoon or night to cool down, and 5 minutes to bleed & refill , done.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-16-2018, 08:59 PM
Recreational Mechanic
Nickshu's Avatar
^^^If you use that method w/ the factory bleeder you need to park the car on a downward incline then run it with the bleeder open.
...But in full disclosure I use an Airlift. Way more predictable, no chance of leaving any air behind, and way easy.
One word of advice...mix and get all of the coolant you need in a big 5 gallon or larger bucket. Once the Airlift starts sucking up coolant into the system you cannot easily switch between coolant bottles w/ the strainer pickup tube without introducing some air into the system.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 04-17-2018, 04:55 AM
svandamme's Avatar
works fine on a flat floor. the bleed valve is the highest point..
in fact downward incline makes the filler the highest point.. that don't work well.
Stijn Vandamme
Old 04-17-2018, 05:02 AM
Nickshu's Avatar
Might depend on the car I guess. On my 996 they recommend parking the car nose down. Maybe not so on a Cayman.
Old 04-17-2018, 05:04 AM
svandamme's Avatar
Thread his a bout a Cayman.
Stijn Vandamme
Old 04-17-2018, 05:07 AM
