Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
need help with this two hole
can anyone tell me what is this two hole for ?
Old 06-13-2010, 05:37 AM
abisel's Avatar
The left hole provides access for welding tongs to spot weld the leading edge of the rocker panel to the bottom of the hinge pillar. I have no idea about the right hole other than possibly an air hole to allow air to escape from the rocker assembly during the e-coat immersion process.
Old 06-13-2010, 06:05 AM
is ok to filler those two holes ? i mean to welder it
Old 06-13-2010, 06:28 AM
abisel's Avatar
You don't have to weld them shut. Instead, fabricate a piece of sheet metal to fit the indent of the space around the holes. Then a dab or two of some seam sealer to hold them in place. The carpeting and threshold trim will cover them up.
Old 06-13-2010, 07:00 AM
thanx ^^
Old 06-13-2010, 09:49 PM
