356 Engine material
can anyone tell me are early 356 engine from 53/54 aluminum or Mag?
thanks Lorne M.
83 SC Last edited by LM3929; 10-15-2009 at 08:52 PM.. |
Help
83 SC |
Aluminum
Thanks now I can try to clean it
83 SC |
Do you have a transmission shop around you can talk to, most have a steam cleaning cabinet should be safr most automatic trans cases are Al
Regards |
This case, like the early 911 is a magnesium case not aluminum and had a coating on it that comes off in the industrial dishwashers.
Most knowing shops won't do them I had the 356 done and by next morning it was showing white corrosion again. Probably just a good steam cleaner would work or pressure washer? Thanks Lorne m.
83 SC |
You might want to check, I am almost certain that the cases are #319 aluminum which a type of casting aluminum. I have also been told that the materials varied. You could have a Mag case or an alloy with magnesium in it.
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena |
Huh? The 911 case was aluminum from production start in 1964 into 1968. There were over 12000 of these cases made before the switch to magnesium. By about 1973 it was evident that the magnesium cases were not up to the task in the RSR and aluminum started coming back. I cannot recall any 356 case I owned that was magnesium.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
This and anothe 356 case is the exact colour of the 911 85 cases that I have and I know are mag.
so why the dark colour on the 356 if it is Alum and why was there a coating on it similar to the 911 cases? Lorne M.
83 SC |
What are the numbers on the engine. That will help us date it.
Sorry to take so long to get back to everyone.
the engine serial #P32926 6130 546 and the is a RS on the top of the case apparently both materials were used in building 356 cases and the mag case had a special coating on it which is my next question anyone know what was used? thanks lorne M
83 SC |
