Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Ignition switch wires
Can someone please direct me as to where in the Factory 356B/C workshop manual it shows where each wire goes into the back of the ignition switch? I have a red wire with a black stripe hanging down unconnected. A quick check shows that everything is working. I can only come up with one place that uses this color wire and that is the clock, however, the clock does not go through the switch and is working fine. I have two empty female receptacles in the #54 grouping, three empty female receptacles in the #30 grouping and one empty receptacle labeled Pa.
Old 05-23-2016, 07:18 AM
I checked the color coded diagram on this site and the only red wire with a black tracer on it goes from the # 2 fuse (verified) to something not labeled. Does not go to ignition switch. I cannot check to see if this unlabeled thing is working. Oh well I'm going to put the switch back in and wait to discover what's not working.
Old 05-23-2016, 12:49 PM
Nothing to do with the ignition switch. My loose wire was for the accessary plug. It is now in place and the switch reinstalled and all is good. I followed the two wires out from the #2 fuse on the black and white diagram in the workshop manual and discovered that the unlabeled thing on the colored diagram is the accessory plug and a quick look revealed that there was no wire connected. Problem solved.
Old 05-23-2016, 03:25 PM
