My other ride is a C-130J
RNajarian's Avatar
“S” Hose Oil Tank to Cooler Replacement Schedule
I’ve drained the oil from my beast in preparation for an oil change. My “S” hose appears to be in good condition and is not leaking. The car is stored in a cool garage and it is driven 600 miles a year. The last change of the “S” hose was maybe 8 years ago.
How often do you recommend changing the “S” hose.
Like an idiot I forgot to add the “S” hose to my order when I got my Carrera fender oil cooler earlier this month.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-07-2018, 08:58 AM
The "S" hose is not subject to much pressure (just the head of the oil in the tank) but is subject to heat. I don't know of a published replacement schedule. I would replace when visible cracks appear or it provides evidence of loosing flexibility or becoming spongy. My guess is you're good for a couple more years.
Old 07-07-2018, 09:20 AM
I changed the "S" hose at the last oil change. Mine still looked pretty good but I thought what is the cost of the hose versus the consequences of it failing.... I would order the hose so that you are ready for the next time.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 07-07-2018, 10:09 AM
Just replaced mine after 10 years. It looked fine but changed it anyway.
Old 07-07-2018, 10:31 AM
RNajarian's Avatar
Yes good advice. I’ll put it on my Pelican wish list
Old 07-07-2018, 10:35 AM
Functionista
manbridge 74's Avatar
I would recommend the Porsche one without the seam you can feel. SOME of the knock-offs are substandard...
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-07-2018, 11:38 AM
brshap's Avatar
I just replaced mine after noticing some hairline cracks that were weeping oil. Its a pretty robust hose. If its not showing signs of wear I'd probably leave it alone.
1984 Carrera 3.2 Targa
Old 07-07-2018, 03:58 PM
BoxsterGT's Avatar
Porsche Crest
Follow manbridge 74's advice.......The Chinese ones are going to fail in short order.
Why risk it? Porsche OE only.
Len
Old 07-23-2018, 12:46 AM
IROC's Avatar
Mine was leaking a little when I first bought my car, so I replaced it (with a factory part). It's been fine since.
That was 24 years ago...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-23-2018, 04:01 AM
theiceman's Avatar
yeah I'm thinking every 25 years or so .... mine was original after 40 years and was not leaking a drop . Was hard as a freakin rock though . Replaced it during my engine rebuild with an aftermarket I think , zero issues.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-23-2018, 05:07 AM
25 years sounds like the right amount of time.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-23-2018, 07:07 AM
RNajarian's Avatar
I ended up buying an OE from our host and replaced it. I acquired this car in 2005 and began keeping a log of maintenance (with receipts) in 2010. The old S hose was perhaps 12-14 years old. It looked good on removal. I’ve kept it as a spare, just in case.
Thanks to everyone for your insight
Old 07-23-2018, 07:12 AM
theiceman's Avatar
lol ive done that too .. and then 15 years later thought " why have I been storing an oily rubber hose that I can buy for a few bucks for 15 years ?
Old 07-23-2018, 08:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
theiceman mentioned the best test I know of- the softness/squish test. If the hose is still soft and you can squish it somewhat easily with your hand, it's still in good shape. Also look for surface cracking when you do the squish test. I've found a handful of originals over the years that are rock hard just like he describes. I also am guilty of saving old S-hoses that are still in decent shape and squishy. I guess I just don't have a lot of faith in newer stuff.
But also look for over-tightened hose clamps. If the previous installer gorilla tightened the clamps, you may find cracking next to the clamps.
This hose is under negative pressure since it's a suction hose. The pipe under the oil cooler is a direct connection to the inlet side of the oil pump. So these hoses typically leak when the engine is not running and the weight of the oil sitting in the oil tank tries to sneak out.
Kevin L
'86 Carrera "Larry"
Old 07-23-2018, 11:48 AM
I lost an S hose on I-95 in SC years ago on my Turbo. I noticed smoke in the rear view mirror then looked to see I had no oil pressure. I immediately cut the engine and headed to the shoulder. The S hose had broken off at the clamp. I jacked the car up, remove the tire and cut off the hose flush where it had broken and reattached it with the clamp. I had enough oil in the trunk to get the engine re-fired and headed to the next exit to get more oil. Luckily it did not hurt the motor.
So, the S hose is something that needs to be checked every oil change. As a matter of fact I need to change mine again.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-23-2018, 05:32 PM
theiceman's Avatar
oil dumping out of that hose right beside the rear wheel on any care would be a puckering experience, never mind a turbo.
Old 07-24-2018, 11:37 AM
proporsche's Avatar
I have my S hose on the 911 since 2005 and still flexes and no cracks.
I say the old saying apply here..if it ain`t broken why fix it"...the materials on new and specially import rubbers are horrible ...even here in Europe..i rather buy parts from old US of A...
than again when i need it..i still have plenty of boxes with all the spare parts i need for my beast
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-24-2018, 11:53 AM
nene's Avatar
I have read that if the hose is not pliable and hard as a rock, that is a good sign of replacing, which mine was.
Old 07-24-2018, 12:10 PM
For me, I change it every 8 to 10 years depending on the miles I have driven. Yea, it may well be fine, but it is just too dang cheap and easy to replace. I have seen one 911 have an old S hose split at an autocross. He dumped the contents of the oil tank all over the course, and of course did a nice ground loop. Fortunately he did not hit anything, and he shut down the engine when he smelled burning oil all over his muffler.
Old 07-24-2018, 12:50 PM
French Import
zippy_gg's Avatar
I change mine as the original from 1986 was still in the car, pretty dry rotten, with cracks showing when I squeezed it.
I replaced with an OEM from PP
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-24-2018, 02:09 PM
