Where was rat number 6?
There should be an official 'rodent find' thread to show all the common hiding spaces.
Old 11-04-2018, 09:11 AM
Someone before me put flares on it.
If you look in the wheel wells it becomes sort of obvious it was not a factory effort.
I may go back and fix it at some point but for now its alright.
The last two rats i found were under the speedometer and the other was in the passenger side hole that the filler neck uses on the drivers side.
The car has devolped a no start condition so i need to sort that out now and I have a small flat spot on throttle tip in.
I called PMO for the part i wanted but he was less than helpful.
1976 914
1986 951
Old 11-09-2018, 07:33 AM
Registered Minimalist
75 911s's Avatar
Post a pic of the dizzy with the new cap next to it. We can help identify the correct cap you need. Also the number stamped in the side will tell what dizzy you have. That's funny about the turbo application on the early 2.7.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-09-2018, 09:06 AM
So currently I am trying to work with PMB to put some S calipers on this and rebuild my rears and replace the rear calipers, the car will stop if you really stand on the brakes but it leaves a lot to be desired compared to my 914.
I really wanted turbo calipers but the cost is keeping me from doing it.
The other thing i was considering doing was sanding my window frames and door handles to remove the black and polish them to a nice shine.
Another thing i need to sort out a little better is the carbs. Been trying to work with PMO
so ill update when i get the parts from him.
1976 914
1986 951
Old 12-06-2018, 10:52 AM
Reiver
Reiver's Avatar
On the tranny issue...check the coupler under the plate on your back seat tunnel. It either needs re indexing/adjusting and/or new bushings. Easy fix and a common complaint on older cars.
De Oppresso Liber
Strength and Honor 5th Legion
Old 12-06-2018, 12:33 PM
Banned but not out, yet..
RSBob's Avatar
Six rats?! You may have the original rat rod.
Great posts. Keep us in the loop.
Old 12-06-2018, 06:41 PM
HarryD's Avatar
Very cool car.
Check your mixture to be sure you are not running too lean as this will also raise oil temperatures.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-06-2018, 07:49 PM
I have replaced the coupler and the selector shaft seal.
weirdly that was the only leak on the car till the oil feed lines to the cam boxes started to seep.
Ive since replaced those as well.
I do have a wideband on it so i have been working on that as well.
Ill post some pictures over the weekend.
1976 914
1986 951
Old 12-07-2018, 03:28 PM
[QUOTE=colingreene;10112421]So my car seems to have difficulty going into 5th/Reverse.
I can shift it into 5th but it wants to stick there, Ill be attempting to adjust the clutch to see if that helps
Looks like an adjustment on the linkage is required. Slacken the pinch bolt next to the coupler and rotate the gearbox side of the shaft clockwise a very SMALL amount. Tighten bolt and check. (Clockwise when sitting in the car looking ahead).
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 12-08-2018, 08:19 AM
Finally got the number off the distrubutor. its marked as
0 237 306 001
Shifting seems to be ok other than a tired 3rd gear synchro.
We did a compression test and the results showed just over 240psi on all cyls.
I am considering pulling it down and twin plugging the motor to get it to run right, or just see what the motor is but my 914 has sort of eaten into my budget a little bit.
Ill include a picture of why that is also.
Heres how it looks now
The brakes are pretty crappy if I am honest heres what the fronts look like, I Have a set of late S calipers I picked up here on pelican that will go on the front and I put these rears on it from PMB.
As always thanks to Eric and the gang for that.
Also yes my wheel well is that clean from just a tooth brush and water, its amazing.
1976 914
1986 951
Old 01-20-2019, 03:09 PM
Im not sure why my pictures are so big.
1976 914
1986 951
Old 01-24-2019, 08:45 AM
Originally Posted by Tony V View Post
More importantly, how are you going to register the car in Ca. with carbs?
I was wondering that too.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-24-2019, 05:39 PM
unimportant, thats my problem not yours.
Anyone know of any window frames in silver being sold rather than the black ones i have.
Door handles also.
the car is a mis match if parts and it bothers me.
1976 914
1986 951
Old 01-30-2019, 08:42 AM
Door handles also.
Gee that is a wiseguy answer......leaves us to assume that "you know a guy!"
03 Boxster
Old 01-30-2019, 12:28 PM
LJ851's Avatar
Thats a LOT of compression !
Old 01-30-2019, 12:45 PM
LJ851 arent you on R3vlimited?
1976 914
1986 951
Old 01-30-2019, 02:24 PM
LJ851's Avatar
Yes
Old 01-31-2019, 04:30 AM
Thought I remembered your thread about your 911
1976 914
1986 951
Old 01-31-2019, 07:09 AM
kent olsen's Avatar
Yeah I don't think I've ever seen that much compression either??
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 01-31-2019, 07:21 AM
Is that really 16-1 compression?
I smell a rat. Or could that be part of the overheating problem?
Old 01-31-2019, 08:14 AM
