First 911 questions
Just bought a 1976 911
The car has quite the story however I am the second owner. I even have a copy of the original issued title from when the car was sold new. Its black on black and what really sold me on the car is that it has a Carbed' 3.0 case motor in it. The previous owner told me stories of his ownership once i managed to get into contact with him. Seems he had a shop back in the late 70s early 80s put a turbo on the 2.7 that came in the car and he admits he knew little to nothing about turbos and turned the boost up to about 10 pounds. In his own words it took the rings out of the motor in short order. So after about 3 motors he told his shop to build him something reliable. That leads me to whats in the car now. 78 3.0L case with weber 46IDA's on the car. Obviously I pulled them off and cleaned them out and re gasketed them. Checked the ports, they clearly have been massaged they measure in at about 42mm And they were sort of dirty. Makes sense because when i went to look at the car it ran on 5 cyls and very poorly at that. Everything in the carbs leaked including the gaskets under the accel jets. That and the shifter was essentially unusable. This gets me back to my point, I cleaned the carbs out got the car to run well enough on my lift however oil temps want to hover around 250. The lines down the side of the car have the usual pinches and they do get hot but What I was wondering is do I need more cooling than the factory 76 trombone cooler offers or is it running hot because I am sitting stationary on a lift. So what I have done so far in my ownership is this Flushed brake fluid. (Actually came out not bad) removed and had the fuel tank cleaned, replaced the level sender dismantled the door trying to solve the non working window (Its the motor) repaired the window switches. Replaced every bushing in the shift linkage and replaced the selector shaft seal Weirdly, astonishingly that was the only oil leak on the car. Removed the carbs, and the fan shroud vac'ed the engine bay extensively and the trunk Found a total of 4 dead rats. cleaned the ports, replaced the belt put new sparks in Scoped the bores and confirmed no stock domed pistons with a set of valve reliefs and repaired the drivers side door panel. Scrubbed the trans where it was caked in oil. Checked the back dated heat exchangers for leaks Adjusted the valves. (not the most fun) Oil change. 11 quarts of oil! Things I want to do, get it running and driving, evaluate what else it needs, not over heat it. I also own a 914 I am doing a 6 conversion on. so This is not my first air-cooled. And I have spent years reading this forum so hopefully my questions are not too wildly out of line. |
Well done getting the car back in shape. We are going to need a picture!
Regarding the temperature, that is way hot for idle on a lift. 250 is what I would expect with no front lines at all, like my 75 was. That's after spirited driving. Once I installed oil lines and a carrera cooler, it's never over 210 - in Las Vegas summers! Even with the trombone, I think you should top out at 240-250 if a hot day and spirited driving. It's good that you got to the rats, but maybe you need to check for further nesting materials around the engine cooler itself. or stuffed around the heads etc. Should have had a pretty good view with the shroud off though. Stick a vacuum up on top of the transaxle. There's a flat spot they love up there. How bad are the pinches? There's a tutorial here to DIY pop them out. It's sorta risky if you asked me. If it were my car, i'd probably upgrade to a cooler with an auto fan. They help a lot. The timing could be way off, did you check that? Could make your motor run hot. Check the oil on a flat surface after getting the car up to temp. A short drive. If the oil is low, it can run hot. 11 sounds about right. Maybe a bit high. |
Sounds like a nice car. Curious, how are you getting your temp. value, a gauge or a temp gun on the oil tank/lines?
If you can swing it, I would certainly install a Carrera cooler given that a massaged engine in California heat will certainly tax the current system. |
More importantly, how are you going to register the car in Ca. with carbs?
http://forums.pelicanparts.com/uploa...1531354199.jpg
http://forums.pelicanparts.com/uploa...1531354199.jpg http://forums.pelicanparts.com/uploa...1531354199.jpg http://forums.pelicanparts.com/uploa...1531354199.jpg Heres the pictures you were asking for. I am uncertain on how to jet the car so I am working with what I have now. The timing is not off, however its still a stock 3.0L distributor with the vac pot for advance. I am seriously considering buying a electronic crank fire ignition system for it because we just put one on a race car at my shop and its one less thing to think of. Also I registered it through AAA just went down and paid the fees it was about 292 dollars. I also needed to buy plates. I guess I did not explain that when i removed the carbs to clean them i also removed the engine shroud and checked the top of the motor for rat droppings, weirdly it and the oil cooler were clean. I have extensively been around the engine and trunk with a shop vac. Right now the only way to determine temp i have been using is the gauge, i need to find my infrared gun to check the tank and other areas. |
if your car is registered as a '76, CA is going to want it smogged at some point. and it won't pass with a carb'd 3.0. you may have deferred that a bit by going thru AAA.
i have a '76 with a 3.2, but i squeezed by the smog monster as my car has a '75 production date was titled from new in CA as a '75. best of luck... |
I know, I am unconcerned.
Moving on. |
That's a seriously nice car. I really like the 3.0L & carb set up, but you will have to do some fancy dancin come time to smog - you'll figure it out. My car is a '69 w/ a '77 carbed engine, so the smog thing isn't an issue. Have fun!
Just got through doing my base tune on the carbs, the car rips.
leaves number 11s in second gear. I do think that the car will get a carrera oil cooler just to be on the safe side. I need to finish buttoning up the door and get the power window working. Don't know what else I really want to do with the car. Likely list is drive the car, find other problems Decide if i need to do anything to the suspension and if so what. replace the bushings in the drivers side door hinge as they are worn. and attempt to get the front window frames to match the rear window frames with the silver anodize treatment. I would really like nicer headlights but these will have to do. While i had the car idling today I noticed a small drip off the thermostat so i bought both crush washers for the thermostat. |
Regarding the temps, are you sure that the sender matches the gauge? If you have the wrong sender you’ll get incorrect readings. Verify the oil temp some other way.
IR gun. Include a fan (such as the American Volt fan) on the oil cooler. You're bound to wind up in traffic on a hot day at some point.
That car looks way nicer than I expected for having found four rats. |
Yesssssss. And LSD to boot.
First 911 questions
Somebody call the SMOG PoPo... You guys are too out of the loop. He said he works at a shop. He’s not concerned.
Definition; I’ve got people for that. Anyone in the business has a contact. As for the oil temp something doesn’t sound right. Verify the gauge. My car was fine on the Trombone cooler. I switched to the Carrera with the American Volt fan Tremuline mentioned because I have working AC and it gets 100+ here frequently. Oh and I drive my car a lot. And you definitely want to freshen up the suspension. The way my car drives after a rebuild is amazing. Those parts are 40 years old. They are done! Sent from my iPhone using Tapatalk |
PS, I remember you and your son from when I used to play with e30s. I lived in Roseville. I think I was 16 at the time. |
I did confirm the gauge matches the temps as displayed on the valve cover areas.
they tend to run around 240. That said the tank and the trombone loop are around 200 to 220 depending on where i hit the loop tank drain nut is a steady 190 While the temps are not wildly out of whack I still agree with the wisdom here and am searching for the best place to get one. I also ordered a cap and rotor for a 78 911 3.0L engine and it showed up too small so that is my next issue, the cap and rotor are fairly worn and id like to replace that to see if it solves my slightly rough running under load. I put in a message to clint at rebel about suspension stuff but if anyone has any suggestions I would love to hear it. the car has a front sway bar but not a rear and some asshat looks like they sazalled the mount off the body so ill have to replace that. |
guys enough with the smog questions.
So my car seems to have difficulty going into 5th/Reverse.
I can shift it into 5th but it wants to stick there, Ill be attempting to adjust the clutch to see if that helps but I followed the directions to adjust the shifter and those were get the transmission into first gear, then move the shifter to as far as it will go in the 1st area so forward and left then tighten down. Is this correct or is their other directions that might be more accurate and or helpful? Clutch does seem to release right at the top. And I am having some trouble trying to find the right cap and rotor for the car. I ordered it for a 78 3.0L however I am uncertain if the caps changed throughout the course of the 3.0L life cycle. I know the 3.2 is not the same. and that the 2.7 Is smaller. The steering wheel has the stitching coming apart and i need to attend to that. So i get to figure out how to remove the horn pad and get the wheel out. Also Id really like to remove the boost gauge and put the clock back into the car. http://forums.pelicanparts.com/uploa...1531945793.jpg http://forums.pelicanparts.com/uploa...1531945793.jpg http://forums.pelicanparts.com/uploa...1531945793.jpg |
Rat count up to 6 now.
Carrera cooler and thermostatically controlled fan has been installed. Part of the reason it ran hot was the thermostat was not allowing hot oil to circulate to the front of the car. |
Though, is that a true 76? looks like a SC according to the rear flares. Or was it flared/widened at rear? A 76 car should be a narrow body. |
Where was rat number 6?
There should be an official 'rodent find' thread to show all the common hiding spaces. |
Someone before me put flares on it.
If you look in the wheel wells it becomes sort of obvious it was not a factory effort. I may go back and fix it at some point but for now its alright. The last two rats i found were under the speedometer and the other was in the passenger side hole that the filler neck uses on the drivers side. The car has devolped a no start condition so i need to sort that out now and I have a small flat spot on throttle tip in. I called PMO for the part i wanted but he was less than helpful. |
Post a pic of the dizzy with the new cap next to it. We can help identify the correct cap you need. Also the number stamped in the side will tell what dizzy you have. That's funny about the turbo application on the early 2.7.
So currently I am trying to work with PMB to put some S calipers on this and rebuild my rears and replace the rear calipers, the car will stop if you really stand on the brakes but it leaves a lot to be desired compared to my 914.
I really wanted turbo calipers but the cost is keeping me from doing it. The other thing i was considering doing was sanding my window frames and door handles to remove the black and polish them to a nice shine. Another thing i need to sort out a little better is the carbs. Been trying to work with PMO so ill update when i get the parts from him. |
On the tranny issue...check the coupler under the plate on your back seat tunnel. It either needs re indexing/adjusting and/or new bushings. Easy fix and a common complaint on older cars.
Six rats?! You may have the original rat rod.
Great posts. Keep us in the loop. |
Very cool car.
Check your mixture to be sure you are not running too lean as this will also raise oil temperatures. |
I have replaced the coupler and the selector shaft seal.
weirdly that was the only leak on the car till the oil feed lines to the cam boxes started to seep. Ive since replaced those as well. I do have a wideband on it so i have been working on that as well. Ill post some pictures over the weekend. |
[QUOTE=colingreene;10112421]So my car seems to have difficulty going into 5th/Reverse.
I can shift it into 5th but it wants to stick there, Ill be attempting to adjust the clutch to see if that helps Looks like an adjustment on the linkage is required. Slacken the pinch bolt next to the coupler and rotate the gearbox side of the shaft clockwise a very SMALL amount. Tighten bolt and check. (Clockwise when sitting in the car looking ahead). |
Finally got the number off the distrubutor. its marked as
0 237 306 001 Shifting seems to be ok other than a tired 3rd gear synchro. We did a compression test and the results showed just over 240psi on all cyls. I am considering pulling it down and twin plugging the motor to get it to run right, or just see what the motor is but my 914 has sort of eaten into my budget a little bit. Ill include a picture of why that is also. Heres how it looks now https://i.imgur.com/0K7DNoc.jpg https://i.imgur.com/0fRKzXz.jpg The brakes are pretty crappy if I am honest heres what the fronts look like, I Have a set of late S calipers I picked up here on pelican that will go on the front and I put these rears on it from PMB. As always thanks to Eric and the gang for that. Also yes my wheel well is that clean from just a tooth brush and water, its amazing. https://i.imgur.com/Ajk1dhX.jpg https://i.imgur.com/FIXN92N.jpg https://i.imgur.com/UadGZZy.jpg |
Im not sure why my pictures are so big.
unimportant, thats my problem not yours.
Anyone know of any window frames in silver being sold rather than the black ones i have. Door handles also. the car is a mis match if parts and it bothers me. |
Thats a LOT of compression ! |
LJ851 arent you on R3vlimited?
Yes
Thought I remembered your thread about your 911
Yeah I don't think I've ever seen that much compression either??
Is that really 16-1 compression?
I smell a rat. Or could that be part of the overheating problem? |
