911sc Rebuild
Hey there
So.. back on this thread (http://forums.pelicanparts.com/porsche-911-technical-forum/938852-chain-cover-question.html) there was speculation about what happened after an over-rev (linkage broke). Well, life got in the way and she sat until Jan or Feb of this year. I eventually got her over to a local place and had it taken apart. Here was the outcome: Yep. That was ground to bits. Literally.
1980 911SC |
New-ish 911SC Targa Owner
how high do you think it revved?
How long had you been using Mobil 1 on this motor? Just curious. i noticed your cam chain pic in the other thread and would expect it to be cleaner if you had a good syn modern oil in it. However, i think driving them like stink actually keeps them cleaner inside than anything else. If this is your first flat 6 rebuild, get ready for the fun! its a great experience to rebuild one. Put EBS on speed dial and prepare to spend some serious change. (but totally worth it)
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
as he had a shop take it apart ,it I am not sure he would do it himself. OP is the shop recommending P and C and valve train refresh ? or do they want to split the case ? The bottom ends of these cars are pretty robust but in your case I'm wondering what they recommend.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
OP, bummer on the grenade but I'm sure she will be back together in no time!
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
I understand , was it just one broken valve ? some of the pics are hard to see detail .
You ll need to check for bent rod and junk through out the fuel injection too.
Bruce |
However, i stand by the drive hard = clean insides. Compare a crown vic motor from a cop car that's been thoroughly thrashed to a similar engine from your aunt Clara's car she only takes to church on Sundays. The Italian tuneup is REAL!
Fleabit peanut monkey
If so, I did this to an early 300ZX when downshifting at speed. Sounded like breaking glass. Con rod had no problem putting holes in the engine block. Very efficient. $500 and a used engine was at the end of my driveway on a pallet. OP cant do that.
1981 911SC Targa Last edited by Bob Kontak; 07-24-2018 at 01:51 PM.. |
Still here
OP, sorry to see the carnage.
Crankshaft and case did alright ? Last edited by pmax; 07-24-2018 at 02:01 PM.. |
Yep, just one valve and the piston was turned into rubble.
Whole thing came apart, and yes the cam was fine and the case was ok. Everything got cleared out, and sent to various shops. She was pretty unloved by the people before me so this was a good Time to go through the whole car. Lots of random issues found. I’ll post some more pics etc soon. This is an over due update so everything is already done (6 months later) Edit: yep they split the case because of all the debris
1980 911SC |
I am my 911's PO
Here's the inside of one of the intake runners. The shiny bits are pulverized piston, cylinder, etc. Assume your entire lubrication system (tank, coolers, thermostats, lines, etc.) is similarly contaminated. I found metal bits throughout. My oil pump housing was seriously grooved so I replaced it. I don't mean to be the bearer of bad news, but this is your chance to head off a repeat performance resulting from an oil passage blocked by debris.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive Last edited by '78 SC; 07-24-2018 at 04:59 PM.. Reason: change photos |
At least you found the other parts of your piston ring!
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Assuming that is a 3.0L motor, it might be time to think 3.6L conversion.
Think 100+ HP
1980 911 - Metzger 3.6L 2016 Cayman S |
...or at least dropping in 3.2 Ps and Cs
if you are replacing them anyway aren't 3.2s drop ins ?
1981 911SC Targa |
Bigger bore, same stroke. But you knew that
What I don't know is are they "drop in's" even though the same bore as the SC? New Mahle 3.2 SS set for the SC is what? Five grand? A single used P&C from a 3.2 is guessing, $250. Gotta get a rod, too. Crank journals?
1981 911SC Targa |
yeah I was talking about the SS. To be honest I don't know a lot about upgrades but when I had my engine apart to do my stud repair someone said something about getting a used set of 3.2s machined out and putting larger pistons.
They could be " dropped in" without any machining of the spigots. Sorry if my wording created any confusion. I am going to look into this when I pull it apart again in about another 40 years .. hmm.. wait ..
So I went to ROW 3.0 and a 964 Cam.
Also was time to lose the cat, and put on SSIs and a dual in/out Dansk sport exhaust. She sounds good now
1980 911SC |
scumbag
i already have a ROW 3.0, SSIs, and 2 in/out. so cams could be a nice kick in the pants to go with my EFI & ITBs.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
