Looking good!
2000 Boxster S and 2016 Audi A6 |
Reiver
Oh, good. I have adj rears too...made that easy. I'd still drive it high water first tho to see what settles.
De Oppresso Liber Strength and Honor 5th Legion |
Looking good. I wouldn't expect it to drop more than an inch after it settles.The online spring plates angle calculators (Will Firch, Elephant Racing) work really well. You're probably going to have to reindex the rear bars. Not too bad a job since everything is new and clean.
Getting closer. Passed 600 hours labor today.
Really want to get the glass in it because I am tired of looking at the open cabin. Have almost all the trim polished. 2 more pieces and then I can try to start installing glass. Got a few projects held up waiting for small parts I cant do without. Need to set a rough alignment also prior to driving it and then I will be ready to get into testing electrics and firing it up.
Almost there.............
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
What I really need is someone with your experience to come help me when it becomes first start time!! |
First Start...........
If we are out from under the shelter at home mess, I would be happy to trek over to your place and lend a hand. Actually, I don't think you will have much problem as long as the timing is close and you got all the bits back on the CIS! That system is pretty forgiving. When I did my engine, I made a bunch of changes to the CIS plumbing and it still works! Send me a text when it's time and I'll see if I can get over there.
Getting real close. Next update should either be the car running or the remains from the fire. Glass install was quite challenging. Pressure tested the fuel system. Had 2 small drips so tightened up those fittings. Fuel system checks good. Need to check the electrical and get the oil distributed in the motor and then I will be attempting first start.
https://youtu.be/MSf3edGKNrQ |
MAN that looks really nice. ... I’d bet you’re having trouble sleeping due to the excitement.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Honestly every time I have worked on it lately things have not been going very smoothly. At this point my confidence is down a bit and I am more apprehensive of the next problem than excited. Im sure it will get there though. Did feel really good to get the glass in. Although the trim isn't exactly perfect at a couple places so it may end up coming back out. |
El Duderino
I really like that you kept the silver trim. I think it looks better with your paint combination than the black would have.
You’re almost across the finish line now!
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
So awesome! Every time I see you have updated the thread, I click in hoping it was for a start attempt. And the day has come, first start-first drive, and the horn works, congratulations! She looks so good out in the sun with those wheels.
Congratulations!
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
Now that the initial exuberance has wore off came back down to the shop to weigh the car and took my wife on a circle around the neighborhood.
Weights before - Weight with 195 lbs in driver seat 2892, FL- 632 (21.9%) RL -862 (29.8%), FR - 526 (18.2%), RR - 871 (30.1%) Front/rear 40.1%/59.9% Left/right 51.7%/48.3% Cross RL/FR - 52% RR/FL - 48% Weights now - Fiberglass rear bumper not installed, and a little less gas. Same weight in driver seat. Probably 50 lbs of gas and bumper would be an apples to apples. Total - 2648 Front 40.1% Rear 59.9% Left 51.4% Right 48.6% Cross RL to FR 50.1% RR to FL 49.9% Roughly 200lbs less. Bumpers, deleted rear seats, RS style door cards, lighter carpet (I think) and probably 30-50 pounds less of dirt and crud! lol Definitely have lots of work to go. Speedo, Tach and clock dont work. (Luckily oil pressure and temp and fuel gauge working) Need to get rear bumper on. (Im enjoying the engine access for now with bumper off) Think the car needs a tune to some degree. Not sure how to proceed on that. Brakes are not good. Need to rebleed them. Need to charge AC system Very limited run time. I am sure many more gremlins will pop up. Pleased with where it sits today though. |
Reiver
Hey...Great Scott!
Woohoo! Awesome Scott!
(man/dude)
Congrats!!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
I'm good with tools.
Way to go Scott. Awesome.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
