wareaglescott's Avatar
Wareaglescott's '79 SC build thread.
Purchased a '79 SC in May and have been enjoying driving it and doing some small projects. The car has 172,000 miles and is a nice driver. Originally a brown car that has been repainted red. Based on where the red paint gets to and some of the components the paint is behind it looks to have been given a pretty good freshening up at some point. The records are minimal as they were misplaced at some point in the past a couple owners back. I purchased the car from another Pelican member that had it for about 5 years.
Here is the car the day I bought it:
My plan was to drive it over the summer and come up with a plan of attack. (I am in Alabama and working in the garage isn't that enjoyable in the heat) The car actually runs and drives quite nicely but I bought it to change it.
To this point I have just done some small projects:
oil change
transmission fluid change
clutch cable adjustment
installed Momo steering wheel in place of original
installed Seine systems gate shift kit
New brake rotors, pads, caliper rebuild and brake lines
A little about me:
Not a ton of automotive experience. Built a Factory Five Cobra kit with a Coyote crate motor. This is my first air cooled Porsche build. Always been a 911 fan. Also own a 2018 C2S. Have a ton to learn on this build and will rely on the fine people and knowledge here!
Desired end result:
I want a nice sporty fun driver. I do not track my cars. Not much of a car show person. I just like getting out in my rural area and driving. I have 2 very fast cars so I don't so much need this to be a fast car. Just a fun car. I already find the car very engaging to drive even though it is a snail compared to my other 911 and Cobra
Plans for the build:
Exterior:
color change- glass out engine out respray
upgrade the headlights from sugar scoops to H4s
Change front and rear bumpers from stock to fiberglass. (Leaning towards the EB motorsports SCRS bumpers)
No duck tail or spoiler of any sort and keep with the standard SC flares
17" Fifteen52 wheels custom painted to match exterior colors
Interior:
The interior is black and in pretty nice condition. Can use some general freshening up.
New seats - I am 6'3" (car has a sunroof) and find I am just not real comfortable in the stock seats. Looking for a seat option that I sit more into than on top of that I can bolt more directly to the floor in a fixed position possibly that will have the end result of a lower seated position with more comfort than what I have now. I am in a rural area with a very minimal car scene so I need to figure out a way to find some seats to sit in and try out. More research needed on this front.
Gauges - would like to add some color that compliments the exterior accent color
Seat belts - also colored to match the exterior accents. Depending on seats possibly a 4 or 5 point harness.
Mechanical:
Engine - I said I do not really need a fast car but I would like it to be faster than it currently is. Part of my reason for this project is to learn more. I plan to pull the engine and do some work on it. The scope of the work is to be determined. It still has the smog pump and AC functioning. The smog pump and its associated components will go for sure. The AC works great and I wold like to retain that. Aftermarket electrical AC systems seem to sound good but that is 5k to replace something that currently works fine as it is so I will have to evaluate that.
Transmission - may or may not need work. This is really the only 915 transmission I have driven so hard to tell if it needs rebuilding or it is just how they are. Need to investigate that further.
New fuel lines
Front and rear suspension upgrades.
Exhaust - would like to upgrade that as well with the hopes of something with a little better performance
Reduce weight were practical. I did weigh the car already and hope to reduce it some but will be retaining the sunroof and AC in some manner so no huge gains are expected.(2698lbs with 3/4 tank gas)
Basically I plan to go through the entire car. Figured it would be a good time to start a thread so I could consolidate my information and have a place for feedback and to ask questions. I am very open to suggestions and help from all the knowledgable posters here so I welcome your input. The car is not original so I have no problem deviating from original spec and making it my own. I am sure they style will not appeal to everyone.
It helps me to visualize my projects before I start and have sort of a goal in mind. Prior to starting the Cobra I had an artist draw up a rendering of the car with the various components I would use. I love blue Cobras with white stripes but I also love to have a unique looking build. When I told my buddies I was going to go with a gray car with orange stripes they thought I was crazy. When they saw the rendering most thought it was pretty cool. When I finished the car and people saw it in person the response has been extremely positive. With that I have a very unique look and I take pride that mine does not look like most others.
Keeping that in mind I thought about doing the 911 in a unique scheme and decided I love my colors so much I wanted to use them again. (well I am 95% sure on that. I may change the accent color but will for sure be using the base color). I had the same artist draw up a rendering with the bumpers, wheels, and paint. I am fully aware when it comes time to sell the car the look will turn off some buyers and probably hurt the value but I accept that going in and am fine with that. I build the cars the way I like them and whatever the end result/value is does not bother me.
Here is what I will be building towards:
Here are the wheels I have crudely colored in with my limited computer skills:
Here is the Cobra so you can see the actual colors:
Thanks for reading. I appreciate any input.
Old 08-16-2018, 10:32 AM
Welcome Scott! I have an 82 SC coupe that I've had for four years now, have done some of the same jobs on my car as you've done on yours, and rebuilt the engine. Mine too has effective A/C and even up here in Connecticut it makes a huge difference. I very much look forward to following your progress. Kind regards, John
Old 08-16-2018, 11:08 AM
I'm good with tools.
AG81's Avatar
Scott,
Looking forward to following this project.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-16-2018, 11:47 AM
Thanks John
Steve, thanks for the lead and inspiration on the wheels!
Old 08-16-2018, 12:51 PM
Munky King's Avatar
Very cool.
Welcome - I’m looking forward to seeing this develop.
You will have great fun (and some frustration, but it’s all character building). I’m still struggling with the ‘while I’m in there’ syndrome. Watch out as it can be catching!
Have I disabled cookies? Well I’ve eaten the heads off a few gingerbread men...
Old 08-16-2018, 01:29 PM
Minimal update.
Had my local painter do some color samples. I am using the same color scheme as one of my other cars and also ordering the wheels with that same color code so I wanted to make sure it looked pretty much the same from one spray to another. Looks pretty darn close. I was to lazy to pull the Cobra out in the sun for a true color comparison but I think it should be close enough for sure.
I have some extra time off work next month so I am preparing to pull the motor out and get to work on the mechanicals of it. Ordered an engine stand adapter. Got an ATV jack and built a platform to lower the motor onto. I am hoping with my 2 post lift and the jack with platform the physical part of lowering the motor should go smoothly. I mean gravity is on my side. What could possibly go wrong?! I already have the engine hoist to lift the motor up and into the engine stand.
Old 08-23-2018, 03:01 PM
4flyboy's Avatar
Love the Colors Scott, welcome!
What equipment do you fly?
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 08-23-2018, 03:43 PM
currently 717A
You?
Old 08-23-2018, 03:58 PM
Under the radar
Trackrash's Avatar
Welcome. SCs are great cars and with a few tweaks they can be a fun and fairly quick car.
If you don't already have Wayne's How to rebuild and Modify 911 Engines, you will find it has much information about possible upgrades.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-23-2018, 05:51 PM
Originally Posted by Trackrash View Post
Welcome. SCs are great cars and will a few tweaks they can be a fun and fairly quick car.
Got it and am currently reading it. Thanks for the suggestion though!
Old 08-24-2018, 03:24 AM
4flyboy's Avatar
Skylane
717A, great airplane pilots love it, currently a restored 1959 C-182 Sklylane straight tail.
Scott
Old 08-24-2018, 05:41 AM
I love the commitment to your War Eagle colors! (Good luck except for Nov 3 - Gig 'Em!)
I'll enjoy seeing the progress here.
Old 08-24-2018, 07:08 AM
LOl the colors have nothing to do with Auburn really but I do enjoy them.
Being an Aggie it ought to really tick you off because I would say it it pretty close to Longhorn orange! haha
Old 08-24-2018, 07:46 AM
Ha - yes, now that I look more closely I see it is more gray than blue and the orange is definitely closer to the orange that other school in Austin uses. Though, I have to admit I think orange is a great color on these cars.
My car is pretty much stock and I love the Petrol Blue color, so I always agonize over things that take it away from stock (though I see mine becoming a scoundrel if not an outlaw over time). I really like artist's rendering of what you're headed for and look forward to seeing it. Good luck!
Old 08-24-2018, 08:50 PM
disband
juanbenae's Avatar
can spare us the 3rd person? gordo holds the rights...
Old 08-24-2018, 10:00 PM
madcorgi
Guest
Posts: n/a
Originally Posted by wareaglescott View Post
currently 717A
You?
As in Boeing 717A? I googled 717A and it came up with a John Deere lawn tractor.
Cool looking build, and very cool garage/other toys.
Old 08-24-2018, 10:47 PM
A is my position as in Captain. B signifies first officer.
Since the guy asking used the term equipment and has flyboy in his name I figured he would get it. The aircraft is just 717.
Old 08-25-2018, 03:48 AM
If you don’t like it just don’t click on it. That makes it easy for me to find vs some ambiguous 79 title that there are already multiple variations of.
Old 08-25-2018, 03:51 AM
Registered Minimalist
75 911s's Avatar
Welcome and I look forward to seeing the updates. I love the rendering! Well, except for the sugar scoops, but you said you were going to replace those so it works out. I think the color scheme with the 52's will look amazing. I like the offset stripes. The SCRS bumper is the prettiest impact bumper replacement option going.
BTW your garage is super sanitary! Is there a Cobra build thread somewhere on another forum? Would love to check it out. They are really fun cars. There seem to be a ton of pilots that drive 911's. I know of 2 in our local group alone but I recall an off topic thread of pilots on here somewhere.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 08-25-2018, 07:20 AM
Travis Neff's Avatar
The grey color on the cobra looks great, what is the color called?
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 08-25-2018, 08:57 AM
