Originally Posted by Abby3.2Carrera View Post
Thanks! Appreciate the offer! I'd love to check out your car when i am in the area.
No worries mine is a local mcl car too so I can walk you through what to look for.
Old 10-07-2018, 11:42 AM
Banned but not out, yet..
RSBob's Avatar
Read through the entire linked thread on replacing window seals and saw zero info pertaining to the OPs question. Yes it’s a good idea to replace seals and catch rust early, did front and back on mine and caught rust just in time on the front, but cracking paint in the outside gutter of the A pillar was not addressed. Both my coupes had the same issue, don’t remember on the 72 targa.
Old 10-07-2018, 12:53 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
Bob,
You don't see a potential relationship between these two pictures? What is your thought about what is causing the paint to lift on the OP's prospective car?
[/QUOTE]
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 10-07-2018, 01:10 PM
Still here
pmax's Avatar
Thanks!
Yes, that's the area. The car I am looking at has a longer crack which spread higher into the gutter and showing a white line crack. paint is original on the roof and I think its original on the pillar too. I will have to take a photo on Tuesday and have you guys to take a look for me.
Need to see the actual photo of the car.
After re-reading your post, I realized it's just a random pic you found online. You might wanna highlight that before folks here get all worked up !
I'll still say based on your description, it's just minor cracking of 30 yr old original paint.
Old 10-07-2018, 03:28 PM
Yes, I forgot to take a photo when I saw the car first time. But I’m going to inspect the car Tuesday, will update then.
Old 10-07-2018, 07:47 PM
sugarwood's Avatar
It's a small crack in the paint in a very irregular spot.
I've seen this in other cars. Get too nitpicky and the car will be sold under you
1986 Bosch Icon Wipers coupe.
Old 10-07-2018, 08:06 PM
very true. If there is no real concerns regarding rust in the area, a small crack won't bother me at all. it's a 30 years old car doesn't matter how you look at it. I just want to be sure since paying a lot of dough for it.
Old 10-07-2018, 08:14 PM
RSBob's Avatar
The paint is original and brittle and there may be cowl shake which causes the cracking. I had very minor surface rust in that area which was removed and treated. It did not compromise the A pillar. It certainly didn’t look like your cancer patient. drawing a conclusion from such a limited sample size is not conclusive evidence of cause and effect.
Old 10-08-2018, 12:42 PM
