I would clean it, put it in the car and worry about its problems as they come up. But im cheap.
82 SC , 72 914 |
1964 Toyota Land Cruiser FJ45 1968 Porsche 912 1970 Citroen DS20 1972 Lancia Fulvia 1.3s Montecarlo |
gearhead
Your engine would be in the 20s today. People need to stop making "years ago" value references to engines and rebuilding. If you haven't paid for this stuff in the last 12-18 months your numbers mean nothing. The market has changed that much. Half the posts in here about cost and value have no basis in the current market and mislead the OP.
In my opinion you have absolutely no business in doing a Porsche project of this magnitude with a 1 1/2 year old in diapers (as seen in pic). Forget it. Sell it.
I know. I bought one that was a lot less ambitious than yours and it's gone very, very slowly in five years. Where's the time? Where's the energy? Sell it. Buy something with an engine already in it - that runs. Trust me, the next ten years are going to go very quickly. The days are long, the years are not. I thought I'd be much farther ahead. I am now happy now, as my 9 year old now turning 10 soon is very much into 911s and is onboard with learning about flat-sixes. We'll see. I'm in no rush now. But remember, I got this car when he was three. |
What I was looking for was some advice on whether or not I oughta keep the 2.2 that O have and get it to work, whether that takes $5k or $15k, or sell it, take whatever proceeds I get from that and the eventual sale of the 912 engine I have in it, and buy something that is already running well. I figured if I can get maybe $6k for the E engine, and maybe $4-5k for the running 912 engine, that oughta be a good chunk of what a running engine would cost, or embark on the refresh/rebuild of the E engine, and use the 912 engine proceeds to help fund that (after the fact, of course, so I can drive it on the interim). I figure it’s gonna cost $3-5k to get it in, mounted, oil tank purchased and mounted, oil cooler and lines run etc once the engine is squared away. Are my numbers way off?
gearhead
Do you weld? The biggest part of it is getting the 911 mounts put in. The rest is mechanical that any decent wrench can do.
Under the radar
Even if it would not be my first choice, a SWB 2,2 E would be a sweet ride. I guess if 912 prices go stupid you could always put it back.
I guess your real challenge will be whether you are going to do the wrenching on the 2,2. Then if you could find an honest, competent, experienced mechanic that you can trust, to help with the details of the motor you would be way ahead of the game. The biggest question mark with this motor is the bottom end and case. The conventional wisdom used to be that the 2,2s weren't too hard on the cases. But with not history on the motor it is a crap shoot for sure. If it was my motor I would pull the top end and the rods. If the rod bearings look good, great, don't split the case. The issue with these motors is with the cylinders, they will probably need work. If they are in spec and there is not corrosion from sitting, you have won the motor lotto. Realistically they will need to be bored or plated. The 2,2 heads are also rather robust, but plan on at least new guides, a good valve job and possibly new valves and machining the sealing surfaces. That shouldn't break the bank if you can do all the wrenching, otherwise like has been mentioned probably a hunk of change to have a pro do all the work.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 10-21-2018 at 11:17 AM.. |
MY engine had no history except for a comment" it was running prior to removal" ,I did notice it had been apart and presumed a top end build had been done @ some stage.It started easily after sitting for 18yrs,lots of smoke and soot but then settled with great oil pressure and no strange noises......this proved you can get lucky.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I don't think it is too hard to build a test stand to verify the engine can run and condition. I built the stand in the pics below before putting this fresh rebuild in my 914. 2x4 and and deck screws with some wheels so I could move it around, total cast around $20. I used the oil tank that was going into the 914 (you will need to get on to do your conversion). Looks like your engine has carbs so easy to get a electric pump and regulator with correct pressure. I used a motorcycle gas tank I borrowed from a friend but was going to use a small boat tank. All the electrical you need for it to run is for the ignition and some jumper wires for starter.As many have said if you lube the cylinders up well and rotate. Crank engine until you have oil pressure ( can measure with multi meter if you don't hook up gauges). Run it for a while and then check leakdown.
john |
You have a 912. You bought a 912. You want a 911. A 911 is not a 912. So I would sell the car and buy a 911. It makes no sense to do this conversion, rebuild an engine to turn a 912 into a 911. You should sell the core engine, sell the 912, take the money and buy a 911. It really makes no sense to hold onto something that is something that you do not want, but think you want, and in the end it will neither be a 911 or a 912.
Either keep a 912, sell it to someone who wants a 912 (there are lots of people), sell the engine to some guy who wants one for his E, and buy 911 which you should have done in the first place. Your numbers really, at the end of the day, add up to nothing. I have seen lots of people go down this road only to realize, as I have said, they should have gotten a 911 in the first place. Last edited by SalParadise; 10-21-2018 at 06:34 PM.. |
Good luck.
I am just saying that these ideas are great and all, and I can see where people lead themselves down this path and it can become a headache. The car becomes worth less. The OP even originally said he has limited knowledge and skill. Why not learn everything there is about 912s and cherry it out? Go through the suspension, brakes, tunnel lines. Make it safe and clean. He can do whatever he wants. It just seems like a false economy when clearly the car has other needs. You could sell the E engine, go top-to-bottom on the brakes and suspension, then maybe new paint, and have a very nice safe car. It just seems like a lot of hassle when the car is already running and it is able to be enjoyed. It seems you could increase your skill level with basic mechanics and have fun with the car, than saying "Lets throw a questionable engine into a questionable chassis, and see there that leads because It's cool and I need the extra 40 horsepower." It's all I have to say. |
Thanks for the input. Again, I am not selling the car. I am going to put a 6 in it. I do not care about the value to anyone else but my family and I, however my funds are not unlimited and I want to be smart with my spending within the confines of this build. I will be moving forward with the sorting of this 2.2E engine, hopefully it doesn’t need a complete rebuild, but if it does, those are the dice I rolled.
I am excited to embark on this journey, and I am happy to be able to keep the car running for the majority of the process.
gearhead
If it were me, I wouldn't even bother with a test stand or putting it in another roller to start it. I would get Wayne's book and embark on a top end rebuild. If it needs bottom end, then cross that bridge when you come to it. Take a year or two to get it done right. Involve the kids in the process and keep driving the car in the interim. This will also let you figure out what is going on with it. An E would have been MFI and it is converted to carbs. It may be as simple as just the carbs or they may have made changes internally to the engine like cams and/or pistons. A top end job will let you figure that out and make sure it is what you want. If you're going to put this engine into your "forever" car, make it yours.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I'm in the "It's your car, just do it" camp.
I'm looking forward to the new thread and next phase of this project.
78 911SC Targa, GP White |
gearhead
Do you have the total type number of the gearbox? Most were just early 901 or 912 gearboxes. However the 902/5x boxes were special ratio race boxes.
