Hybrid 911? Anybody see this?
Ran across this over the weekend while doing a little suspension research:
Vonnen Boost For Porsche – Electrifying Performance Looks to be a very cool concept and will be interesting to see this implemented on air cooled cars. I cringe at the price tag. Am guessing that gearboxes will need a fair amount of strengthening. Pretty cool! Thoughts? |
a.k.a. G-man
cool but pricey!
Сидеть, ложь, Переворачиваться |
Looks like Vaporware to me. What are you going to do with stage 1 at 175hp? My old TT and my '75S have more horsepower than this. And they are old.
gearhead
Except they had several running driving ones at Rennsport.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
![]() ![]() ![]() Mated to a Rothsport built ST spec 2.5. The one on the stand is a PDK and water pumper. I think they will sell more of these for Carreras and Caymans. |
Hey guys, I'm happy to answer any questions about the system. We have the 991 system close to customer-ready and will be delivering 2019 Q1. And it rips.
The 175 hp in stage 1 is PLUS 175 hp. That puts a garden variety 991 into about 500 hp and a GT3 into 675 hp. Air cooled cars will follow and will be customer-ready later in 2019. Figure the power-add to be similar.
Chuck Moreland - elephantracing.com - vonnen.com |
Curious as to how many BTU's of heat is created by the MGU and how is the liquid cooling managed?
1980 911 - Metzger 3.6L 2016 Cayman S |
With electric motors, it's more about the torque than the HP. ICE develop peak torque at 2K+ RPM. Electric motors deliver peak torque at one RPM. A company I have stock in makes powered wheels that add massive torque to cut acceleration times.
https://orbisdriven.com/honda-civic-type-r/ Of you're old enough to remember JATO, this is the automotive equivalent.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Liquid cooling is independent of the engine cooling system. We have added two separate cooling systems, one dedicated to the battery, the other handling the MGU and controller. Both are ethylene glycol based. There are dual radiators, one dedicated to each circuit. I don't have a BTU number for you.
Chuck, I got to meet you at RRVI. Thanks for being so helpful with my questions.
This concept is one I've been hoping to see available for years. I hope to see more in the future. |
How much weight does this package add and how is it distributed?
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
"Weight: Net 120 lbs (stock flywheel, starter motor removed, 12V battery replaced with lightweight unit) The system total weight is partially offset by removed components; stock flywheel, starter motor, and 12v battery size reduction. The net system weigh is just over 100 lbs." Distribution looks to be pretty even, with the battery in the frunk, controller in the rear and motor/generator in the center. |
Net weight impact is about 120lbs. We have some offsetting savings since we remove the flywheel, starter motor and go to a light weight battery (since the 12v system is not starting the engine).
Our MGU and controller sit in back, and battery module goes in the trunk. the 12v battery savings is close in location to our battery module weight. The flywheel/starter motor savings are close in location to the MGU and controller addition. All-in weight distribution moves forward slightly, but not dramatically. Filling the tank with fuel is a much bigger shift.
Saw it at Rennsport, very cool, would be a nice bump for the aircooled cars.
Chuck - Are you recommending any modifications to gearboxes to handle the increased torque?
With respect to the need for trans mods, we have total control of torque delivery. This provides great flexibility with respect to the trans, CV joints, clutch etc. We can program to work with the stock trans without problems.
On the air cooled cars, there are a variety of trans options; G50, 915, 911, 901, 930 each with different torque handling capacities. We can program the system to accommodate each. We constantly monitor a variety of inputs including gear selection, RPM, and throttle position. Our VCU combines these inputs with knowledge of the trans and engine capability to make decisions about how much torque to produce at any given time. We can limit torque to remain within the operating limits of the drive train As a simplified example we can limit torque based on gear selection; 1st is limited to 50 ft lbs added, 2nd gets 100 ft lbs, 3rd+ let her rip, etc. But it gets more sophisticated than that, we can torque-fill. The engine has a torque curve that climbs, then dips with RPM. We can map to add more torque when engine torque is low and less torque when engine torque is high, thus creating a flattened torque curve from idle to redline. We can set that summated flat torque curve to remain within the operating limits of the drive train, and elevate it if the trans has been modded to accommodate more.
and are very excited to be out with it publicly now. RR was great as the coming out party for Vonnen, glad you could stop at our display.
Ubi bene ibi patria
Not Really A Hybrid
![]() ![]() A buddy recently sent me these photos of a Tesla modification. There were no details attached. Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
That's the E RWB car from Streetfighter LA. We provided the suspension for that car. It was just at SEMA in the Toyo display.
gearhead
