87 Carrera turn signal woes
Symptoms:
>4-way flashers work as they should >with power on, and with both the old flasher relay or a new one, both left and right turn signals flash fast when either side is activated by column switch, as when a bulb is out, but bulbs are fine (they work when 4-way is activated) >Here's the kicker: with power OFF, when right turn signal is activated by switch on column, it comes on steady both front and rear (not flashing). This does not happen on left side. >Could there also be a connection between this problem and why my left fog stopped working (i tried a new bulb). I'm inclined to think the problem may be in the column switch, but looking at wiring diagram I'm not convinced. However, a couple forum threads suggest a relation, even to the fog light problem.
Paul '87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff. '96 993 cab (gone, oops); '82 SC (gone) Last edited by Paul Crowther; 12-30-2018 at 08:56 AM.. |
Check ground connections, right side works the way it should left side doesn’t. I have been cleaning contacts in my rear lamps every year to keep them working.
40 year old fixtures. Turn signal contacts can be cleaned also. |
To recap:
Left turnsignal on: Both front and rear turnsignals hyperflash (2x normal flash rate) Right turnsignal on: Both front and rear turnsignals hyperflash 4-ways on: All turnsignals flash at normal rate. That you get normal flash with all 4 corners flashing but hyperflash with only R or L turnsignals on indicates that the load of the bulbs is enough for normal flash with all 4 corners but not enough of a load with just 2 corners on. So how do 2 normal 21W bulbs not cause normal flash? One way is if the ground is removed from the front turnsignals. This would cause current to flow from the bright filament through the dim filament to ground. When checking this out, pop off the front turnsignal lens and see if both filaments flash when on turnsignal.
Find Spoke's LED Products: www.spokeworksled.com |
2manyprojects
On my 86, with ign off moving the signal left or right lights the indicated side for overnight parking. Normal for 86 year, not sure about your 87.
I had an issue with one side parking lights, there was a diode above the light switch that had failed. But I did not notice an increased flash rate. |
Recreational User
Your left side should be working that way too, though. Note that the hazard light circuit is a separate circuit from the turn signals. You should check all the relevant fuses at the fuse panel to make sure they're good, and then also use the fuse panel diagram to check that all the wiring is correct on both the power side (input - top of the panel) and the load side (output - bottom of the panel). With turn signals activated and flashing too fast, and with a bulb removed, use a multimeter to measure the voltage going to the socket. If the voltage is too low, due to unwanted resistance in the circuit as a result of corrosion or loose connections, the relay may not see enough of a load (similar to having a burned out bulb) and cause the fast action. |
![]() Spoke, regarding your comment about the ground being removed from the front signals, the photo shows the connectors I'm working with. The circled red connectors go to the spades as indicated, but the yellow connector seems to have no place to go. I THOUGHT it went to a spade on back of socket, but since that spade is aluminum it didn't make sense. Does it get connected to anything?
Paul '87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff. '96 993 cab (gone, oops); '82 SC (gone) |
I recently removed my front bumper to have it painted, so I have some photos of how all this stuff gets connected. Unfortunately this forum doesn't allow you to post photos from mobile phone. If you don't get it figured out by Wednesday I'll post them when I get to office. But yes, there are connections for all those wires.
Black/White: Turnsignal power Gray/Red: Running light power Brown: Ground The Gray/Red and Brown wires have additional spade connectors which connect to the 2 male spades on the back of the bucket. These 2 wires go to the sidemarker. The brown ground spade connects to the reflector body in the picture below. On my car, the bottom spade on the back of the bucket is ground. These 2 wires to the sidemarker can be swapped if the sidemarker is an incandescent light bulb. If an LED bulb is used for the sidemarker, the polarity of these 2 wires is important. I've run into a few cars where these 2 wires were connected backwards and an LED sidemarker wouldn't light up where a bulb would. ![]()
87 911 Fron & Rear Lights Wiring Diagrams
This should help with your tail lights making the proper connections.
![]() ![]() SW - Black WS - White RT - Red GN - Green GR - Grey BR - Brown BL - Blue LI - Violet |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diode.
![]() ![]() ^^^^^ Not showed in the above CKT. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 12-30-2018 at 12:09 PM.. |
Diode.
![]() ^^^^^ The diode is either open, or disconnected. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
The diode is shown in the top right of the schematic. The diode is part of the Euro-park feature so the license plate lights do not come on when the car is off and the turnsignal stalk pushed to the right side. This diode was dead on my car so I just bypassed it.
[QUOTE=spoke;10300338]There are 5 spade connectors in the wiring of the front turnsignal bucket. 3 wires come from the vehicle:
Thanks again, all you Pelicanites!
Fixed. The problem was in my reconnecting the wiring to the faulty side, I matched “what went where” to the the locations on the other side, but things were reversed on that other side. The tip-off was that on the two sides, different filaments were lit in their respective bulbs when the running lights were on, with one too bright and the other too dim. I switched the leads going to the faulty side’s bulb socket as well as to the spades at rear of housing. Voila! Happy New Year! 💥
Paul |
Max Sluiter
So I recently replaced the hazard switch on my '71 since the plastic clips were broken and it didn't seem to work that great (inconsistent timing) but the turn signals worked ok besides both indicators in the tach turning on instead of just one. After a bit I realized the new switch has a slightly different pinout than the old one so I might have fried something there but eventually I corrected the wiring (moved the ground pin in the connector) and the hazards and turn signals both still didn't work. Then I replaced the flasher relay since the old one had clearly been tampered with and smelled like it may have been fried. The new relay got the hazards working but then when I tried the turn signals I get the 2x hyperflash in each direction.
Are the new relays different from earlier relays, maybe they are designed for higher amperage? I don't think I have that diode. I have 911R style taillight/turn signal units, no license plate lights, and no fog lights in front, just the front turn signals up there (and the headlights). The 4 bulbs all seem to be functioning fine. I could try higher wattage bulbs though. Anyone have suggestions for how to proceed? Seems like checking grounds again?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
If the new flasher hyperflashes and the correct lights blink on the outside, then the flasher is sensing low current like the bulbs are flashing through the running light filaments. This could happen if the bulb sockets are not grounded. I assume you have 21W incandescent bulbs in all 4 corners.
To see if what I suggest might be a bad ground, look closely at the lights when they flash to be sure just the high power filament is lighting up. Does the hyperflash change when the headlights are turned on?
Max Sluiter
Thanks, I will check the wattage and observe the filaments more this week. I haven't tried the signals with the headlights on yet. The aftermarket light housings could very well not be grounded well.
Max Sluiter
So it appears I have 5W in front and 18W in back. Not sure on the front though- 5W sounds really low. It says P21/5W. Sounds like that could explain the hyperflash. I have an electronic flasher relay on the way though, hopefully that will fix it.
The 18W vs 21W bulb difference seems too close to make the flasher hyperflash but it might be it. One way to test this out is to put a load of two 21W bulbs on the flasher. It should then flash at normal speed. You can do this by removing both rear turnsignal bulbs leaving just the front two 21W bulbs in the circuit. Then hit the 4-way flasher and see if two 21W bulbs makes it flash normally. OK, shameless plug here: you could install an EP26 flasher and replace the bulbs with LEDs like these ones. These are for the Hella 911R fixtures like yours. This is the 2nd set I've made. I forgot how cool these look with 48 LEDs jammed into a 2 inch diameter circle. These are very bright. One set are brakes with red LEDs and the other are turnsignals with 1/2 in amber and the other half running lights/brakes in red. The bases are printed and replace the entire base/sockets of the OEM unit. ![]() ![]()
Find Spoke's LED Products: www.spokeworksled.com Last edited by spoke; 11-18-2022 at 09:21 PM.. |
Max Sluiter
That looks cool, do you have pictures of them lit up on the car?
I took the car in for some other servicing and with the holidays it may be a while before I can test with just the front bulbs, but thanks for the suggestion.
