myamoto1's Avatar
Factory part, but I think there are aftermarket versions available. Here's what you want (not my part, no affiliation, etc):
https://www.ebay.com/itm/196955179839?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoqJ2B_cD-3t_CXLxocgCzc29ohf6yvarnt7lihX9lDYReV0GIGcP9I
I didn't find it offered by our host with a quick search.
If you want to backdate both sides:
https://www.pelicanparts.com/More_Info/93010632102.htm?pn=930-106-321-02-OEM&bc=c&SVSVSI=0583
Josh
85 M491 Coupe - "Fat Bastard"
Old 10-17-2025, 09:50 AM
Tremendous. I appreciate it. Is the fan etc solely for the purpose of providing heat? Removing them doesn't cause any other issues? To be honest, I like theidea of being able to actually see both intakes in the engine compartment with it removed.
Old 10-17-2025, 11:50 AM
myamoto1's Avatar
If you can find the 930 version, if memory serves me right, it has slightly better clearance around the distributor. I do remember taking mine to the anvil for some minor clearancing.
Josh
Old 10-17-2025, 12:38 PM
OK, hopefully my last question. I am having VERY difficult time getting the section hooked up to the right/passenger connection. I am assuming the one with the slightly longer connection and the "adapter" thing is for the right/passenger side. The other one with the shorter connector and no additional threaded connector went on fairly easily. No matter what I do on the right side I can't seem to get the connector lined up with the fuel rail connector, it is interfering with the intake manifold. Any tips from someone who's put the Mason fuel lines on a 3.2 would be helpful.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-17-2025, 04:23 PM
Never mind, I reversed them and that fixed it.
Buck
'88 Coupe, '87 Cab,
Old 10-17-2025, 06:44 PM
myamoto1's Avatar
Just took pics for you, but glad you figured it out. I thought you might have had them reversed.
Old 10-17-2025, 07:53 PM
Does anyone have detail on how the pressure regulator is removed, maybe a diagram or picture? Thats what's holding me up.
Thanks!
Old 10-17-2025, 11:01 PM
Here is pic of my old one I replaced. Turns out it’s working perfectly. You can see the threaded portion at the bottom which is how it’s attached.
Old 10-18-2025, 11:39 AM
Another pic still hard to see the bracket it bolts to.
Old 10-18-2025, 12:00 PM
Is this the bolt that holds it in?
Old 10-18-2025, 02:20 PM
Hi guys, for better or worse I’m not very active on the forums. I am however always happy to try and help once you get ahold of me. My email is mason_paul@yahoo.com and my phone number is (734) 740-4919.
Thanks again everyone!
Old 10-18-2025, 04:35 PM
Hey Paul, if you have any instructions on removing the pressure regulator, I'll take it!
I got the return line fitting off!
Old 10-18-2025, 07:09 PM
Old 10-18-2025, 07:19 PM
I can’t say I recall any tricks here. I took off the airbox and everything except the intake manifold…and the rest was lots of reaching with box wrenches and some mirror work. It’s not easy.
Old 10-18-2025, 07:56 PM
I would love to have basic tips about actually installing the engine fuel line(s). Just a one pager with notes on which line goes to which fuel rail (I initially got it backwards) Also, the best way/order to tighten each of the 6 or 7 connections. I noticed if you tighten the center 3 way "T" shaped connector the end connecting to the fuel rail would be mis aligned. BUT it needs to be placed in position under the center piece of the intake before it's tightened since I needed to have the end loose to maneuver it under there. Detail on the route it takes at the back so it actually reaches the fuel filter would be helpful as well. I finally got it in but I think I now see it’s out of alignment for rhe filter and a bit short so will need to re route it. It's an EXCELLENT product!
Buck
'88 Coupe, '87 Cab,
Old 10-19-2025, 07:33 AM
myamoto1's Avatar
I agree with Paul, if you haven't pulled your airbox, it'll be nearly impossible to access the regulator. Similar to many things on your Porsche, you're removing nuts and bolts you can't see. I highly recommend getting a small mirror to help with locating hidden fasteners. I also often hit video record on my phone (flash on) and stuff it back into those hard to reach areas to get my bearings.
Old 10-19-2025, 08:42 AM
myamoto1's Avatar
Also look back at page 2 of this thread and you'll see the bracket the regulator mounts to. I think your yellow arrow is pointing to the correct bolt. I found it easier to remove the entire bracket and regulator as one piece.
Old 10-19-2025, 08:58 AM
Yeah all that has been removed although the airbox removal is more important for the right side of the engine etc. Hopefully that bolt is the one left to go. I just didn't feel the bolt head back there...I 'll keep trying.
Old 10-19-2025, 09:07 AM
49willard
I did an engine/trans drop several years ago to refresh all flexible lines and while in there did 1/2 shafts heater flex hoses etc. I considered doing the fuel hoses with engine in but am glad that I did the drop.
Bill
1961 356B coupe-long gone!
1986 Grand Prix White Cabriolet
Old 10-19-2025, 11:15 AM
Ok, I got it. That was not the bolts I was looking for!
It's the ones facing the camera. Actually easy to reach when you use the force. Lol
Old 10-19-2025, 01:50 PM
