-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Replacing Engine Fuel Lines – ’88 911 (http://forums.pelicanparts.com/showthread.php?t=1030675)
Coolair911 10-19-2025 01:48 PM
What's the secret too getting the nut free in the picture below? This is the bracket that holds the old steel fuel line in the back of the engine. I have put penetrating liquid on it and it still will not budge, I'm afraid I am going to round it off and then really be up a creek without a paddle!! Any help/advice much appreciated.http://forums.pelicanparts.com/uploa...1760910476.JPG
wazzz 10-20-2025 01:04 AM
If I remember well the nut is actually welded to the bracket, so you don't want to turn it. Instead, you want to remove the bolt which has its head facing the front of the car. You can't see it on the picture. You need a tiny ratchet with an Allen bit of the correct size (can't remember, must be 6mm at most). The bolt and black plastic fixture will come off while the metal bracket with welded nut will stay on.
88911coupe 10-20-2025 05:59 AM
I believe Gilles is correct as far as I recall. IIRC, there is a longish bolt that holds the black plastic bracket in place.
Coolair911 10-20-2025 06:39 AM
THANK YOU! Will see if I can get a mirror back there again, fist try I could not see anything in the black plastic holder. It’s the only thing remaining from me getting the old lines out. Thanks again!
thsupernge 10-20-2025 07:21 AM
Isnt this the one that is held in with an allen? If so, one you have the right one, it's pretty easy to remove.
NY65912 10-20-2025 07:23 AM
I'm pretty sure it's a 4mm Allen screw. I found it impossible to get. I wound up removing the intake completely, which was a good thing. I replaced a ton of little items while I was in there. See my old post,
https://forums.pelicanparts.com/porsche-911-technical-forum/798923-my-thoughts-carrera-fuel-line-replacement.html
Coolair911 10-20-2025 07:21 PM
Thanks to all, it was indeed a 4mm Allen head bolt on the other side of the weld nut. MANY THANKS!! All the old lies are out, now in with the new Paul Mason lines!!
