derek murray's Avatar
MFI Pump / partial load factory setting
I need to set my pump’s partial load / main rack adjustment back to a factory (or reasonable starting point) setting. I can’t seem to find any info in the factory manuals, CMA, or online, so any help would be appreciated.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 06-25-2020, 09:53 AM
initial adjust
Take your bottom adjustment and turn it all the way in.Then back it out 24 clicks and start.You need an AFR gauge to set the main rack.Ciao Fred
Old 06-25-2020, 10:00 AM
Thanks Fred, I’ll do that for my idle adjustment setting.
I’m able to test AFR, but was hoping for a starting point for my partial load as well. A PO had it set so far out that the adjustment screw fell into the sump with my first turn! I suspect it was messed with to address a whole host of other issues (bad injectors, sloppy throttle bodies, poorly adjusted linkage, etc) that have been addressed this winter.
'70 911S 1002938
Old 06-25-2020, 10:55 AM
