Had to do a before and after shoot
-------- 1977 911s |
AndreasK, nice work.
I've been looking to do similar with my 1977. Looks like you also did a rear bumperette delete. What did you fill the holes with? Are use using the original Euro rear rubber corner strips? http://forums.pelicanparts.com/porsche-911-technical-forum/335141-european-vs-us-bumpers.html ![]() Rear rubber strips be they Euro-spec or US, same length? ........................................... Rear wheel flares, SC, ST or something else? Thanks for the info, will do a search on those threads. I've only seen the custom light weight crush tube threads.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 09-16-2020 at 06:03 AM.. |
@kach22i
Holes in bumper was plugged with a JB weld type "metal". The car is a US model, so the corner rubber is the US ones. However I think they are the same as the Euro. The flares I actually think are "RS". Previous owner installed them. But they are pretty much the same as SC. Mine are fiberglass 😥 Next project will be to change them to steel😀🤓 |
well done, looks very nice
Thank you for the information.
When I took my bumperettes off the steel bolts in them had expanded/rust and made the hole in the aluminum bumper irregular and enlarged. I cleaned and then filled the hole with an epoxy faux metal in a small cylindrical container, similar to the below. https://www.jbweld.com/product/steelstik-epoxy-putty-stick I think there might be better ways to do it, so thought I would ask. I do like your wheel flares, not standard SC and would keep them.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
JED
How about your source for the rear plate lights? I just welded the bumberette holes on a spare SC bumper. I have a set of LED plate bolts but your clean.
I’m not typically a fan of the stying changes made on 964s but man yours look really good. Especially with those wheel.
I too prefer G bumpers on a G body. Some of my favorite Porsches have accordions Good job
Tony |
Bored, slow work day. 3 feet of snow outside. Looking back on last years drives
Honestly, those 30mm front/25mm back are just PERFECT.
Good job!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Haha. Thanks! I spent hours measuring, visualizing, changing my mind over and over. Think I got it just right, so it was worth it
Sideshot of the tuck
Nice tuck! Mine’s a work in progress, but I’m liking the less weight on the ass end!
77 911s 16 981gts |
![]() 2014 https://forums.pelicanparts.com/porsche-911-technical-forum/807533-rear-bumper-concept-explored-w-sketch-2.html
