what in it's design makes the 915 notchy?
I have set up my 915 to the best I could, and it's going fine. The whole mechanical link from shifter to gearbox has been fitted with new bearings, and the coupler been delicately adjusted spline after spline till best response. Every 10th or so downshift from 3rd to 2nd asks for a double clutch. Apart from that, it's going fine.
However, it rarely feels like 'butter', and any gear change needs some more force than I am used to in other cars. No grinding or weird noises however, just some notchy feel as if it needs to be pushed over some cam. Hence my question: what parts/gears/syncros/sliders/ etc in the gearbox are causing this resistance ?
Old 10-30-2020, 12:00 PM
Like Porsche is a two syllable word, the the 901/915/930 transmissions are a two syllable shift, due to the balk ring syncro design. There needs to be a split second of time allowed for the shift to be accepted. You should not over-rule that moment by forcing a shift. As syncros and shift sleeves rub on each other over the years, the rough friction surface on the syncro wears off to a polished surface and the sleeve, can't slow or speed up the free-wheeling gear fast enough for a nice, reasonably quick engagement.
206 637 4071
Old 10-30-2020, 12:23 PM
proporsche's Avatar
Yup this....as John said...
i always told my clients between any gear shifting, one second delay
1985 911 with original 501 645 miles...807 319 km
Old 10-30-2020, 12:38 PM
One thing I've found is many 915's have been converted with the factory short shift lever. That makes the shifting much more notchy. I always convert back to the regular lever, longer throw, but so much smoother.
As John said, it's a two step motion to shift these. At first resistance of gear engagement, pause, then finish your shift motion. It becomes natural fairly quick.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 10-30-2020, 01:00 PM
Even better learn to double clutch; gives required pause and makes changes really smooth when you get it right. Downshifting needs blip of throttle and then there's heel and toeing for braking and downshifting when approaching a corner. Getting it right adds a whole new level to the fun.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 10-30-2020, 01:47 PM
There's nothing you can adjust or replace in the linkage that's going to overcome an issue in the gearbox. I've owned many 911 3.2 G50's, but this most recent was my first 915 car. My car has pretty low miles (mid 40's) and it shifted more or less as you describe yours does; occasionally balky and needed a double-clutch downshift, occasional noise going into 1st unless at idle, a little vague in feel, etc. I installed a Wevo shift coupler and dialed it in carefully after much trial and error, and it was a little better (less vague) and just got used to the character.
I had a very knowledgeable air-cooled tech drive the car for an opinion, and he immediately said it has some broken dog teeth in at least two gears. I decided to address it immediately rather than waiting for further issues. When he pulled the motor and opened up the gearbox, it turned out to be exactly what he thought, along with a cracked pressure plate. He replaced all synchros, dogs, and sliders, etc. I haven't picked it up yet, but I'm really excited to see how much better it drives. I guess the moral is that I assumed that mine was just normal based on everything I've read about the way the 915's shift, and obviously that's not the case. I'd bet that is most of these are in need of the kind of freshening that mine needed, and if you think yours has an issue then it probably does, and new bushings, couplers, and fluid isn't going to fix it. The upside is that if the gears themselves are fine (mine were) that this isn't' a very expensive job (probably under $5k).
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 10-30-2020, 02:38 PM
Racer
winders's Avatar
915 transaxles shift just fine. You should never have to double clutch a downshift. The balk ring design just means you have move the lever a little slower.
If it doesn't shift properly, there is something wrong inside.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-30-2020, 02:52 PM
I think you’re right, just be precise and slow with changes. Be it the 915 box in my 72S or the G50 in my 993 Cup RSR, change precisely
Old 10-30-2020, 03:18 PM
Lash
I picked up my first Porsche 1972 911-T at the factory in September 1971. I kept it for seven years and it had just over 42,000 miles when sold. I never had the problems shifting as described in this thread.
I have a 1980 SC and I have the same problems as the O/P describes. I do not know the exact mileage because the 85 MPH speedometer was replaced but paper work I have indicates it may have over 60,000 miles.
I have replaced all of the easy to get to parts that have been mentioned in other threads on this matter including the clutch.
So as Winders suggests its best just to slow down the shifting until I can rebuild a worn 915 transmission.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 10-30-2020, 05:55 PM
