How does this connector come apart?
87 Targa - I'm replacing the speedo sender. The photo shows the connectors in the tunnel, for the wires from the sender to the speedo itself. I'm not seeing any seam in the plastic cover and am just assuming this 35 year old plastic is getting brittle, so I don't want to get too brutal with it. Any idea how these things comes apart? Thanks.
just pull it apart;-)
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
The connectors housing does not come apart, it's one piece. You pull the wire and the spade connector inside disengage and come out.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks yelcab. That crossed my mind but I just didn't want to destroy the thing.
I appreciate it. |
look inside the connector you might see the small tag that keeps the spade terminal in
Lorne M.
83 SC |
Irrationally exuberant
Many (most?) spade connecters have a tab that keeps the metal connector inside the plastic sleeve. You push the connecter in from the back, the tab compresses and when the connector is seated, the tab spring open again, locking it in the plastic sleeve.
To remove the connector, shove a very thin piece of metal into the mouth of the plastic connector (but outside the connector itself) to depress the tab. You can buy a tool for this but if you have an old windshield wiper, you can pull out the spring steel metal in it and use that. You may need to to grind the side of it for smaller connectors. ![]() ![]() ![]() ![]()
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
'73 911 T Targa
It appears that the male connector is integral to the plastic cover and that only the female connector gets removed. I'd reach in with needle nose to grab the connector. If it doesn't come out easily, it probably has the locking tab that Chris mentioned.
Wildman Emeritus
I have had the plastic disintegrate on a couple of these. I replaced them with bullet connectors with shrink tube fitted over the connector for security and short prevention.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
You can get the spade connector out by using a small screwdriver to push down the tiny
clip inside that holds it in. |
Heck, I’m only 5 not 71!
Use two small needle nose pliers to hold the crimped end of each connector to pull apart instead of pulling on the wire. Why take the chance of pulling the wire out of the crimp.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
